I am unable to identify what these sounds mean.
What is disturbing is that at the end of these sounds it reboots and then ARMS ITSELF with Mission Planner reporting that it is DISARMED.
The kill switch will NOT disarm the aircraft.
I can not make this error happen, it just does. Occasionally I will get a normal boot.
No errors show on HUD, no errors reported in logs.
Any help is welcome and appreciated!
The fact remains that this error code, as it is sounded from pixhawk is either being misinterpreted or is not in the listed library of error sounds.
Upon recalibrating the transmitter these problems appear to have ceased. Testing in progress.
Removing the kill switch does not fix the problem
Replacing the kill switch does not fix the problem
This error is truly intermittent
Formating the SD card has no effect
The self arming only happens when this error is present. This multirotor has more than 100 sorties. Trying a few things, will report back.
format the SD Card and see if your issue goes away.
