The Sky Eye-25HZ is a ruggedized, high performance 25X electro-optical zoom camera payload designed for demanding applications that require high quality and precise images, like inspection for building, power lines, tower, pipelines etc. High-performance 3-axis gimbal is using advanced FOC(field-oriented control) motor control technology which will enable you to get a 0.01 degree incredible precise control, so the gimbal will give you crystal clear and stable video footage.
25.9 megapixel still image
Still image resolution of Sky Eye-25HZ reaches up to 25.9 megapixel, click HERE to check building inspection images.
Compact and lightweight
Sky Eye-25HZ weighs as little as 782g to help you meet your payload weight allowance
Easy for integration
Sky Eye-25HZ can not only be controlled via PWM signal, but also serial command. Also gimbal status(like Yaw/Pitch angle,zoom position etc) can be obtained by sending serial command to the gimbal via its serial port, which is really useful for precise gimbal control and system integration.
Clean and simple wiring
Sky Eye-25HZ comes with one wiring hub for RC receiver and video output port, which makes wiring pretty easy and clean. Also the gimbal offers 2 smart speed modes: FAST speed and LOW speed.Fast speed mode is used for small zooming range,which makes the gimbal control sensitive and quick. LOW speed mode is used for large zoom range, will enable you to target the object more accurately.
Features:
1) 782grams, lightweight
2) 1/2.3 inch CMOS sensor
3) 25X zoom capability, 1080P/60 HDMI output for video downlink
4) Still image resolution: 25.9 Megapixels
5) 4K video recorded for on-board TF card
6) PWM control and serial command control
7) Convenient wiring hub for RC receiver and video output
8) 3-axis high stabilized gimbal system
9) Adjustable control speed: SLOW speed for large zoom range, accurate. FAST speed for small zoom range, sensitive and quick.
10) One key back to home position
Photos
