ArduPilot Board V3, assembled
We're now testing the ArduPilot code on the real board (not just a breadboard prototype), which is the through-hole version of Beta 3. A few notes on assembling this board, if you've got one on order:
  • I've updated the parts list in the original post to reflect our recommended configuration (with pigtails rather than right-angle servo and RC receiver connectors)
  • The GPS connector doesn't have as robust a physical connection to the board as we'd like (we need to tweak the board to give it a little more room). If you're using this board, you might want to epoxy it on before soldering its electrical connections.
  • We accidentally designed this board with a surface-mount reset button, when the reset button that comes with the Boarduino kit that we use for parts is through-hole. I've listed the surface-mount part you need in the original post, but we'll tweak the board to use the through-hole version in the future.
  • Use the jumper that comes with the Boarduino kit to bridge the power selector pins (top left corner in the photo above) for the option you want: power from the RC receiver or another source. I use the RC receiver and it works great, but if you want power redundancy you may want to go with a second battery just for the autopilot.
    Thanks for the prod, Brian. The first production candidates failed (a wrong chip got placed) and we're now testing the second production candidate. Maybe another month?
    Hi Chris, when you get a chance can you post an update for release. Thanks, - Brian
    Again, all info will be released in Sept. I've already mentioned a target price of around $30 for the basic ArduPilot board (you'll also need to get a GPS module and the FMA Co-Pilot) and perhaps $100-$150 for the ArduPilot Pro, which has GPS and co-pilot/stablization functions built in. ArduPilot basic will be released first; we hope to releas ArduPilot Pro by the end of the year.
    Yes. You'll probably have to splice the connector, but otherwise any GPS that outputs NMEA is fine.
    Phil,
    That's correct.
  • Hi...
    ATTiny Pin1.
    I assume this is hiding behind the resonator X1
    The board is not marked and I have not looked too buch at the schematic.
    I got the 157D on the board OK.
    Phil
    Chris,
    I finally got my board, but it's the previous verson. I see the obvious difference in their layouts. Am I going to have success using the earlier board or do I need to just use it as a practice platform for my soldering skills (or lack of...)? The plus side to this board is the reset is the correct one to match the boardino kit... Do you have a photo of one of the earlier boards assembled? If you do could you post it or send me a copy?
