A  large scale Variable Pitch Tilt Quadrotor implementation.
3689439619?profile=original
Here is a description of a Variable Pitch Blade Quadrotor build with some unique features. It is a large Quad, and can be quickly split into 2 halves, enabling easy packing into a carry case for simple transport. The ‘Upper’ half of the quad contains all the electronics, IMU, Autopilot, Payload control electronics, etc. The lower half carries the battery packs and the payload. The upper and lower halves slot together and are affixed by means of 4 captive spring release screws. The payload similarly mounts to the underside of the lower body half. The entire Quad can then be separated into an upper and lower body half, and payload.
Each motor has a standard ESC ( not any fancy hi-speed update type…) mounted beneath the motor. This keeps the 3phase motor leads very short, ensuring little electrical noise radiation from said leads.. Beneath each ESC is a small CPU module which receives a serial command from the Autopilot. This serial command contains the desired motor speed, the blade pitch angle, and the rotor tilt angle for Yaw control. This small CPU module generate the relevant PWM signal to the blade pitch servo, the rotor tilt servo, and to the ESC, while monitoring the motor RPM, ensuring constant motor speed, as commanded.
 The upper half of the Quad has 2 Variable pitch, variable Tilt, same direction rotating rotors. The lower half has only two variable pitch same direction rotating rotors fitted. The motors are operated at commanded constant speed, and lift is varied by blade pitch, giving much faster control of individual blade lift for stabilization. This is a problem with conventional control by motor speed variation, as the rotor blades become larger in diameter. The inertial mass of the rotor increases, and it becomes increasingly more difficult to rapidly change rotor RPM, both to enable horizontal stabilization, and to control Yaw.
 The Tilt rotors are both fitted to the upper half of the Quad, with the rotors spinning in the same direction. This ensures that when the rotors are tilted ( always in the same direction) to control Yaw, Gyroscopic Precession is equal and opposite across the two rotors, thereby canceling out. Gyroscopic Precession also begins to play a bigger role in larger diameter rotors, when the tilt rotor concept is employed.
 The construction is almost complete. So far all simulations and math shows we should have around 2.5kg lift per rotor head, with an all up Quad weight of 5.5kg, inc 2 of 6cell, 6000mAH batteries, leaving around 2kg for payload. We should get around 15 to 18minutes flying time.
 If it looks like it came out of the ALIGN Factory, it did not…I used parts from the Trex600 series chopper, the tail rotor pitch assy, etc, as well as tail boom, stays, and a few more bits and pieces…The composite parts were all modeled in 3D CAD, and molds made for them. All the custom Aluminium parts were likewise modeled and CNC machined.
 Basic Specs:
Dimension from blade tip to blade tip – 2100mm
All up weight – 5.5KG, inc batteries, 3.4kg exc batteries.
Blades – Trex 450 style.
Variable pitch on all 4 blades.
Variable Rotor Tilt on 2 blades.
Max payload mass – 2Kg.
Estimated flight time with 1.5kg payload – 18minutes
Autopilot – NamPilot
I hope to fly it real soon now….!!
Just running out of space for all the aircraft here!, Guppy, Hornbill, Kiwit, all the 60 trainers, ……Need some sky-hooks!
Regards
Joe
‘The NamPilot’
Two unfinished body Halves:
3689439629?profile=original
Cutting out lightening Holes on the CNC:
  3689439537?profile=original
2 halves with IMU:
3689439485?profile=original
Lightened Central Hub Assembly: (with unpainted autopilot cover)
3689439756?profile=original
 3689439704?profile=original
CNC Machining of Motor Arms:
3689439781?profile=original
 The Pitch Tilt Arm:
3689439725?profile=original
The Variable Pitch Motor Assembly:
3689439656?profile=original
The Variable Pitch and Rotor Tilt Assembly:
3689439794?profile=original
Partial frames fitted Together: (floor squares are 300mm X 300mm)
3689439734?profile=original
Frames in Transport Mode:
3689439678?profile=original
  • Another pic 3692330065?profile=original
  • I would suggest same cross stiffeners on those boom supports to stop the vibration caused by the flexing boom to travel back to the center hub.
    I have lost a couple of heli´s due to this vibration and the APM definatly wont enjoy it !
    3692329978?profile=originalBTW Ellison, the CNC machine can´t craft CF (A grinder can).
  • Santa helps those, who help themselves.  Maybe you can use your grinder to build the CNC machine.
  • Very, very nice and very well done.
    I asked Santa for a CNC machine, but I only got a grinder !
  • Great job so far!
  • Joe, decreasing the wire diameter will increase the number of windings per stator and result in more torque.  You can go the route of increasing the number of stators and diameter of the motor too, but then the additional weight is a problem.  So really a question of which will give you more a bang for the amount of power you're pumping through the wires without generating excessive wasted heat.
    Someone really needs to redesign the way we make motors, pumping current through copper wires, is so 20th century!
  • Just love what you have put together.
    Like the angle off your presentation.
    Looking forward to see it in the air ...
  • @Sean,
    Yes, the Gyroscopic forces are large. That is also why I have two opposite rotors with the tilt mechanism as opposed to only one, as in a tri-copter - the gyroscopic precession forces cancel out, resulting in a net zero effect on pitch or roll of the aircraft. However, the force to tilt the spinning disc remains, and that is quite large! In sumulations I have rotor tilts of less than 0.5 to 0.8 degrees to stabilize Yaw in all modes of (gentle!) Flight. This Quad is not intended to be highly agile, but as stable as possible. At least it is all a hell of a lot of fun!
  • @Ellison,
    I have done some fairly extensive measurments comparing low kv outrunners with geared high kv inrunners. For the most part, for the same shaft speed and thrust figures, the inrunner requires less input watts, at midrange thrusts up to 12% less. However, the weight of the geartrain and associated elements required 7% more thrust, which at mid thrust required 19% more input watts....Not easy to win!
    I am convinced the way to go is a pancake shape, large diameter motor, of around 120 to 150kv.
    I am not sure how the thinner wire will help? I think in essence the number of poles must increase, so we need more stator arms and more magnets. More stator arms take up more space so then thinner wire would help, but IR losses go up and motor efficiency goes down...As I said in my comments to Alex, scaling physics down often just does not work very well...
    And 70minutes flying time for the MD4-1000 really needs to be accurately qualified with a proper spec of the setup, weight, altitude ( air density) , etc. To much Smoke and Mirrors in to many Vendor claims!
  • @ Alex
    Thanks for the comments Alex. I agree that in the mathematical world the effectors are seperable, but physically any action on one rotor has a strongly coupled reaction to the others. And the situation is worsend as we scale down in size...The same applies to the CH-47. The rotor blades of the CH have high inertial mass and so a very low ( millihertz) flap frequency. In addition the Reynolds number for those blades are orders of magnitude higher than our poor little blades, so the lift stability is much better. Physics does not scale well for the scales we play at..BUT, it still works!
