After being stuck dead in the water for 6 wks waiting for a new Tx.... Today was the day to do some real testing. The weather was almost perfect, little gusty but not to bad. I did some rough PID tuning in the garage late last night, and soldered the 3 Gyro pads. It still wants to drift and the YAW might just need some PID-Tuning to get it acting right. The front Left motor with all the vibration must be replaced. I can really tell in the video that the copter is fighting with it as well as the gustyness and the YAW + Drift. Right before the Crash I had almost full forward stick but nothing was happening. Then soon as I let off the stick it freaked out. The Quad frame worked out as intended. Protected the electronics from hard landing / crash. I would rather destroy the chassi than the electronic's. So now time for new motors, and a stronger frame.
3 of the 4 motors purr like kittens, but that other one is worthless. The bearings don't fit snug in the case, lots of wobble. Witch causes it to unload. I will say i could tell that the foam really help dampen the vibrations and was a lot less noiser than my aluminum frame.
FLick,
can you explain a bit more on the "unload" point ?
if i get it right it's the point at about 10% throttle usually where the prop (even a well balanced one) make considerably harder vibrations, while just a bit less throttle it doesn't happen, and just a bit more throttle it stops vibrating,
it behaves like some kind of self-resonance, when it reaches some frequency.
and yes, this point is usually not enough throttle to lift anything.
these vibrations are kinda bad, i always wonder how can it be stopped, but anyways the hovering throttle seems to usually be higher than this point...
@ Flick
850 grams all up weight
Turnigy 25amp ESC's
9x5 props Hobby King
Turnigy 2822-1400kv motors I think they might be a little small each motor pulls around 6.5 amps
11.1v 2200 mha Lipo = 7 min flight sometime I use 2 for 11-13 min flights
I have to replace all the motors before I fly again. I would like to switch to the purple arducopter motors and 10x4.5 props. HK motors are hit or miss with quality and always on backorder. UGH!! In the mean time I will be building a new foam chassi.
None of the props came loose, all the motor connections are soldered. It Just Freaked out on me. wierd......
another one bites the dust! :) I was debating to fly tonight or not... will see if the wind goes down a bit.
So your frame is bent or not? hard to see in the video at the end...
