Due to the limitations of minimosd, for some time that I've been working on developing a new OSD for APM/PX4.
As of today, AlceOSD 0v3 is available for sale at: www.satxo.com
Firmware available at: https://github.com/diydrones/alceosd/
Documentation is available at (WIP): https://github.com/diydrones/alceosd/wiki
The firmware is open source project so all kind of contributors are welcome!
Let me know your thoughts and new ideas for the OSD!
Latest flight (hw 0v2):
First flight (hw 0v1):
Batch of the first 10 prototype boards:
Assembled board (2.5 x 5.0 cm, 6 grams weight):
I'd vote for just C. C++ for embedded systems feels cumbersome unless it is complex. Because the OSD simply receives the MAVLink/UAVtalk messages, things are fairly straightforward. My two cents.
Elios, great ideas. The radar is definitively on the road. AlceOSD has a lot of flash memory and implementing all that should be a matter of "just" coding it.
That playUAV board is also new to me, but it seems to be a mix of the crappy max7456 chip (same as minimosd) plus some rendering by the cpu.
I also plan to add support for UAVtalk (openpilot) but as for DJI can it will have someone to code it as I don't own one.
Looks very interesting. I just found playUAV OSD, also. http://diydrones.com/profiles/blog/show?id=705844%3ABlogPost%3A2002...
The most frustrating thing with unlimited rotation gimbal is you don't know which direction the camera is pointing and it is very confusing.
Intriguing. :)
Well I can only guess ..My hunch is you are clocking SPI Ram to drive the display?
As for the C v C++ debate.. . Unfortunately C++ got me hooked 20 years ago ... but as any C programmer knows.. C++ is only good for code bloat ;)
Anyway will follow this with interest. it certainly looks very good!
regards
Andy
I like pure C :)
The RAM is "big thing" in my OSD design since I don't think anyone has done it before (at least that I know of).
I'll be publishing more details as soon as I can... like I said, it's going to be completely open source.
Some would say no C++ is an advantage ! But yeah it would need to be gcc4.7 to be useful.. no matter
Anyway I'm interested in your RAM useage. I remember seeing somewhere that you are doing an interlaced display but I can't see a likely dsPIC33 with more than 48K Ram on board which doesnt seem enough. (I'm assuming a double buffered display) Are you using external RAM for the display buffers? OTOH Quad SPI is nice to have!
regards
Andy
HI Andi,
It's using a dsPIC33EP512xx504 but it's also 100% compatible with the 256Kb flash version. Microchip gcc is based on 4.5.1 but no C++ as far as I know.
Hi again Luis,
You say you are using a 16 bit dsPIC. Care to say which one? You must have a good amount of RAM on it at least to get interlaced display?
I might try to get my API working on your hardware. Does the Microchip version of GCC compile C++11 . Do you know what gcc version it is based on?
regards
Andy
Hi Elios,
Please leave them here: https://sites.google.com/site/alceosd/forum
There is a topic called "Wishlist" where some people already left some ideas.
Based on that topic I'm filling up a development plan here: https://sites.google.com/site/alceosd/firmware/development-plan
Luis
