The AMA is claiming that the FAA has "forced" them to become the "manager" of recreational aviation that will force every recreational sUAV user to be a member of the AMA or not be able to fly.
From one of the AMA's "ARC" FAQs:
"AMA would prefer to see a single set of guidelines managed by a community-based organization
that establishes the standards for all of model aviation. AMA is actively developing a
comprehensive set of model aviation guidelines from its current safety standards for submittal to
the FAA and hopefully acceptance and approval before the sUAS SFAR becomes a reality in
2011.
This may sound to some like the Academy is trying to force all modelers to join the AMA.
Certainly AMA believes there is strength in numbers and the health and welfare of the hobby
undoubtedly depends upon the presence of a strong national organization that can speak for and
advocate the interests of the aeromodeling community. But, forcing modelers to join the AMA is
by no means the intent of the Academy’s approach to the sUAS rulemaking. AMA’s sole aim is
to work through this issue that has been somewhat forced upon us, and achieve an end result that
allows the modelers to continue to enjoy the hobby in much the same way as they have in the
past"
Seems like a sneaky way to bolster their falling membership by millions. The AMA has no oversight policy for its members or clubs and its safety policies are based soley on what an insurance company will allow. Let us hope that the AMA will be ignored by the FAA. A set of atandards for everyone to follow instead of forcing everyone to get an AMA insurance policy is what is needed.
Seems like the USA is starting off behind!
Still at least being an AMA member means the operator will have seen some of their safety information.
3 months 8 days 13 hours 8 minutes until you all start finding out whats in store.
LOL
LOL... nicely put ;-)
All in all the AMA needs to just open a nursing home and call it a day.
All they will do is raise premiums and accomplish nothing except empty the pockets of millions of hobbyists. Might as well make the Gecko Secretary of the State and the Caveman President. Welcome to the new U$A.
The same could happen to the AMA, given enough hobbyist support... another organization could obtain group policy insurance and offer it piece-meal, thus placing modelers in compliance (were such compliance mandatory).
" In the end, the FCC determined that the 220 FCC (headed by yours truly) had more membership support than the 220 SMA, and that it was indeed also considered a bona-fide frequency coordinator acting in a quasi-governmental capacity. A summary of the findings, and their implications, appears here."
I will bet that 220 FCC did much more than sell insurance and peddle magazines. : (
But there are two separate recommendations. Under AMA rules and policies; not under AMA rules and policies.
The latter (section 3 of the sUAS ARC) Some in the AMA want to drop this section.
If you are under 2 lbs you fly basically unrestricted.
"3.3.6 Notwithstanding the above limitations, Model Aircraft weighing less than or equal
to two lbs incapable of reaching speeds greater than 60 miles per hour (mph)
(52 knots), and powered by electric motor or mechanical stored energy (e.g., rubber-band powered) may operate within 3 NM of a military or public-use airport
or heliport; if they remain a safe distance from the airport or heliport, remain well
clear of all manned aircraft, and remain below 400 AGL."
Keep it in mind that this is a small subset of the rules for UAS. There is going to be an explosion of UAS in law enforcement, crop surveillance, you name it.
The FAA wants to keep it under control so that there are no accidents. I doubt if there will be any part of the regulations that involve the AMA or the FAA in an active fashion. I was involved in ultralight aircraft in the 1980's when the same thing was going on. The FAA didn't have the money to actively regulate ultralights, and they don't have it for sUAS's either.
I see a set of regulations to keep it pretty much like it is with more detail for modeler use.
If you want to fly commercially then I am sure that it will be much more available than a COA. I would still expect a huge leap in paper work and expense.
Monopolies are never a good thing.
