I'm pleased to announce that we've joined forces with the other Arduino-based powerhouse in the aerial robotics world, the AeroQuad quadcopter team, to extend the ArduPilot platform to whirlybirds of all kinds. The project, called ArduCopter, will use the ArduPilotMega and IMU shield hardware along with a low-cost custom platform that will be available commercially to provide a full quad UAV with both stabilization and GPS waypoint navigation. It builds on the awesome work of Jose Julio in ArduPilot quad development, with the excellent full-systems integration of the AeroQuad team. We expect that first code and hardware will be available this summer.
And here's the impressive work of the AeroQuad team:
Another team is also extending this to traditional helis, starting with the Trex 450 heli (and its equivalents), which should be ready for release this fall. Along with Blimpduino, this should make for 100% coverage of all aerial robotics platforms on the Arduino platform, with shared libraries and ground stations across projects. Go Arduino!
We'll be setting up a proper microsite here, along with dedicated tab, for the project in the next few days.
If you haven't already seen this preview of what the ArduPilot/ArduIMU combo can do with quads, check this out:
Here's the announcement from the AeroQuad team:
ArduCopter - The Full Featured UAV Multicopter!
Hey guys, as many of you know the AeroQuad has teamed up with DIY Drones on developing a very full featured multicopter! Chris from DIY Drones has proposed the name of this new effort to be called the ArduCopter! It will be based on the ArduPilot Pro Mega (APM) and the APM sensor board currently nicknamed the Oil Pan. Here's an initial feature list and software road map. Please chime in! Your input is valuable! I'll keep updating this front page until we agree on the first version of the ArduCopter's capabilities.
ArduCopter Feature ListSoftware Roadmap
- 6 Degree of Freedom IMU stabilized control
- Gyro stabilized flight mode enabling acrobatics (loops and barrel rolls)
- GPS for position hold
- Magnetometer for heading determination
- Barometer for altitude hold
- IR sensor integration for obstacle avoidance
- Sonar sensor for automated takeoff and landing capability
- Automated waypoint navigation
- Motor control using low cost standard PWM Electronics Speed Controllers (ESC's)
- On board flight telemetery data storage
- Mounted camera stabilization capability
- Wireless command & telemetry for long distance communication
- Capability to fly in "+", "x", hexa and octo configurations
- Battery level detection
- User configurable LED flight pattern
- Capability to use any R/C receiver
- ArduCopter Configuration and Ground Control Software
- Realtime graphs of flight data
- GUI for configuration of PID and other flight parameters
- On Screen Display integration
- Waypoint programming using Google Maps
- Mixertable view to auto configure "+", "x", hexa and octo configurations
- Initial baseline using Jose Julio's v3 software
- Provides absolute angle PID flight control
- Obstacle avoidance
- Waypoint navigation
- Generalize basic ArduCopter functions (ie. Separate PPM receiver input and motor control functions into separate libraries. Allows future coding of PWM vs. I2C ESC's)
- Emphasis on developing new capability into easy to use C++ libraries
- Integrate user defined EEPROM storage capability
- Develop/optimize AeroQuad serial real-time command/telemetry for ArduCopter
- Integrate AeroQuad Configurator for external software configuration of ArduCopter
- Rename Configurator to Ground Control Station and integrate graphical programming of waypoint navigation
- Integrate AeroQuad rate PID control
- Integrate mixertable configuration for multicopter configurations
- Integrate AeroQuad camera stabilization
- Integrate I2C motor control
- Develop capability to wirelessly control ArduCopter directly from Ground Control Station (USB joystick controller from laptop or through waypoint programming)
For your radio.. Go and get that Turnigy 9X if they still have stock in HK. Getting 6ch radio now as your first radio is a bit "waste" of money due rather soon you want to have 1-2 extra channels... You know appetite grows while you eat :)
Even tho Turnigy is only around $60, it's well worth it. Ok might have some minor problems with switches depending on batch but hey you can always change them later is cost it only like $0.50 each. I had small problem with one switch and especially it's lock nut but drop of CA glue solved that. After I got my TGY, my old $400 Futaba has been just collecting dust on shelf..
Thanks for your reply to my question Jani! I am a bit of a RC noob and with so many acronyms being thrown around sometimes its hard to keep up with what is what.
I am going to start poking around and see what I can come up with for a cheap but reliable radio and reciever for to start off with. Anyone have any suggestions as to a cheap radio that is good for beginners that like to tinker with settings?
I like the DX6 but I have seen that there are some available for around $60. Would it be worth going the super cheap route to start off with, or should I bite the bullet and go ahead and purchase the DX6?
when will the ArduCopter frame kit be available?
Thanks,
Toby
One quick question. Can some give me a good list of parts that will not be included in this next kit release so I can start looking around to find them? Thanks and keep up the great work!
Our ArduCopter is 1008gr 2200 mAh battery included last time I checked it.
between 600g and 1Kg ready to fly.
Peter
@Scott, Xbee Pro it your choice. We know that they work properly withour any hickups. Some people has been able to make Series2 and Series2.5 but usually it's just short distances and slow speeds. As for Configurator, it does not matter what type of method you are using to connect between laptop and quad as long as speed fits on both ends and not missing characters on transmission.. You can even use bluetooth if you want :)
Configurator does not know anything about transport layer, it just talks to Serial ports and expects feedback from it. If you are fast enough to send even morse code with flash light... Configurator will be happy :P
I am glad you mentioned this. I had the same yaw issue on VER 1.34 and for time being downgraded to VER 1.33 which seems more stable.
Scott,
In VER 1.34 you can enable xbee support and use it with the configurator by un-commenting "#define IsTEL". In VER 1.33 you will need to search and replace all Serial.print to Serial3.print.
If i change from X to + config on the same quad after very successful flights in manual mode should i expect to use the same gain in + mode as i had in X mode?? And do i have to perform an initialise??
T
16
17
18
19
20
of 82 Next
