I waited 8 hours for the US time zone so that even the west coast could answer. I am out of luck also with your support. No answers. Is this a bank holiday in the US ?
Not receiving answers, I changed the cables the way I thought, i.e. crossed them
Now compass is showing a weak light. Power from I2C measured on red cable and ground is only 1v. Shouldn't it be 5v ? Then no wonder the compass is not working.
GPS is perfectly fine.
I have tried not connecting compass to I2C's power and ground to see if it would catch it from the GPS.
I purchased my 3DR APM 2.5 in Belgium in August, along with 3DR GPS/compass.
APM 2.5 was not working after one week, sent it back and received a 2.6 instead.
Problem is with the compass cable to I2C
1- It does not even fit the I2C plastic stuff. I had to take it off to have the pins naked, then I plugged it in.
2- Compass does not seem to talk to I2C whatever I install, desinstall, reinstall, external comp settings, and so on. This problem has been on and on for 4 weeks
3- I realise now that compass pins are not lined up with APM I2C pins, but my compass=>APM I2C is straight (all 4 cables going parallel). Cannot work like that right ? I must have been supplied with the wrong cable ? Shouldn't it be crossed ?
I have received an explanation for the invoice. It seems this is an internal document for shipping support. As an 35 year accountant, I can understand this. I think the invoice should be noted as a shipping document. and remove pricing.
It turns out that I was being shipped a GPS cover. The good news is I did not need the cover and let customer server know that. This is a good example of over reacting and I owe the warehouse and apology. I am sorry for over reacting.
This is a good time to talk about a customer rep Lexie Lex. She has been the most helpful CS rep I have ever worked with. If you want your shipping problems solved ask for Lexie. Tell her Tony sent you.
Done.
No hang on, I used the contact page from your site asking for support, I did not send an email to help@3drobotics
Is this the right thing to do from the start ?
Yes I did this morning and I should allow for 48 hours for an answer. That is why I am begging for support in this forum.
Frejus: Have you sent an email to customer support? help@3drobotics.com
Red light on external 3DR GPS/compass is very weak when connected to I2C and GPS not connected to APM
Red light is very strong when GPS is connected to APM
But compass still failing to initialise, or "not enough data" when trying to calibrate. A dead compass I paid 80 euros / 100 dollars.
I am getting tired of trying to make this APM work evenings after evenings.
I expect DIY to fully work when I do things correctly. This is DIY but even when correctly done results are not showing.
I ordered another external compass, not from 3D Robotics. Will see if it works.
I2C only providing 1v worries me.
No luck neither.
Thx
in the 6 pin plug, skip #5 black cable assuming #1 is red
1 (red)
2 (black)
3 (black)
4 (black)
5 skip
6 (black)
1
2
3
4
5
of 14 Next
