APM to CHDK Camera Link Tutorial
[Edit 12/31/2015: Note for Pixhawk users that Canon cameras require a 5V pulse to trigger so a voltage step-up from Pixhawk's 3.3V output is required. See compatible cable and link to more instructions here.]
ArduPilot Camera Tie-In Tutorial
This tutorial will show you how to get your CHDK-enabled camera connected to your ArduPilot Mega (APM) without buying any extra hardware or decoding PWM outputs. You might want to make this connection to take advantage of the camera trigger function based on distance covered, to ensure a certain overlap and to avoid excessively high overlap. This modification is not necessary, if you have a CHDK camera and want to keep it simple, you won’t gain much by switching to this method right away.
For this tutorial, I’ll use an SX260 HS but this should work equally well on any CHDK-supported Canon Powershot camera. You’ll need just the supplies below to make the cable. The SX260 uses a USB Mini-B connector. Most Powershot cameras come with a USB cable, you can just use that one to be safe.
APM CHDK Connection
If you don’t have a crimp tool to attach the servo connector, just take a spare servo wire and solder the wires together instead.
We’ll only be using the Mini-B side of this cable, so measure whatever length you need from that end depending on how your camera and autopilot mount in your airframe. I’ve measured out about 14″ and cut the cable completely through. Inside are four wires, we only need the red and black wire so cut away the green and white wires. Strip the ends of the red and black wires.
SAMSUNG CSC
If you have the crimp tool, crimp and insert the wires into the first and third positions of a 3-position header. If you don’t have the crimp tool, solder these two wires to the ground and signal wires of a spare servo wire. Insert the ground wire into the side with an arrow so you can tell which wire is which later on.
SAMSUNG CSC
Cover the connector with heatshrink. Be careful with the hot air near the connector as it can cause the locking plastic pieces in the receptacle to deform.
CHDK Cable
Now plug this cable into pin A9 on the side row of APM. The text doesn’t line up exactly so be sure to count rows. SPI takes two rows, then A11 and A10 are two more so there should be 4 rows of free pins, then our new connector.
APM Relay Pin A9
If you already have CHDK installed, just install the script file (right click, save link as) into the scripts directory on your SD card. If not, follow instructions for installing CHDK from the page corresponding to your camera atthe CHDK wiki. Load up CHDK and go into the menu then navigate to Miscellaneous Stuff -> Remote Parameters and make sure the Enable Remote setting is checked.
SAMSUNG CSC
Now connect to your APM and open the Full Parameters List in the Config/Tuning tab. Set the parameters as following:
  • CAM_DURATION: 1
  • CAM_TRIGG_DIST: Depending on overlap required.. be sure to keep in mind the normal downwind speed of your plane as well as the maximum rate at which the camera can take pictures. For the SX260 and the E382 that’s once every 2.7 seconds and about 18m/s. I plan to operate below those condition in most cases but I do like to get as many pictures as possible, so I set my distance to 49 (meters).
  • CAM_TRIGG_TYPE: 1
  • RELAY_PIN: 13
Params_CAM
Params_Relay
All that’s left is to test it out. Load the E38_APM.bas script file like any normal CHDK script and start running it. If you can get a 3d fix inside, you can test it on your lab bench just using USB power. Just set the CAM_TRIGG_DIST to 1 or 2 meters and let your plane sit on the desk. Small movements between GPS readings will cause the distance value to count up slowly and it should trigger the shutter every few seconds.
If your camera lens closes and opens instead of taking a picture, make sure the CHDK remote enable setting saved properly. If nothing happens at all, take your APM outside and walk around to make sure you are getting some distance covered.
Original Post
  • Thanks for the great tutorial. Can anyone help me work out why my camera won't trigger from the A9 signal pin?
    I know my cable and CHDK are okay because the shutter triggers continuously if I connect the USB signal wire to the + power rail. I'm using APM 2.6, ArduCopter 3.1.5, Mission Planner 1.3.7, with CAM_DURATION=1, CAM_TRIGG_TYPE=1, and RELAY_PIN=13. Any suggestions very welcome.
  • The script also plays with exposure to maximize the settings you want (like shutter speed).. but realistically you can just use the Tv mode and get the same result 99% of the time.
  • Im using ArduPlane. I believe its version 2.78 on the APM and 1.3.0 as well as 1.3.1 on Mission Planner. I guess Ill try reloading my APM firmware as much as I'd hate to. My plane is flying like a dream and just as soon as I reload the firmware on it... :(    Anyways, here's a pic just to show.. The list is in alphabetical order and as you can see, there is no Relay_Pin parameter. 3701728174?profile=original
  • It was in  ArduCopter V3.1.2, not sure about V3.1.3.
    RELAY_PIN value 13 = APM2 A9 pin
    I switched back to ArduCopter V3.1 and is also available with it.
    You might expand Jeff's images indicating the locations in full parameter list to make sure you are looking in the right place.
  • Yes I still have that parameter using even 3.0.2 released just a few days ago. And that's running Mission Planner version 1.2.99 I think. You're not using ArduCopter, right? I'm not sure about that, this is all in reference to ArduPlane.
  • Enable remote was checked and I double checked the pin count multiple times. It was working back when I had access to the Relay_Pin parameter. Now that it has disappeared from the parameter list, its not working. I have the check box for the advanced Full Params checked as well.  Jeff, do you still have the "relay_pin" parameter showing in your params? If so, what firmware versions are you running on MP and the APM?
  • There is an option in CHDK that needs to be checked, it's called something like "enable remote trigger" or "USB shutter control", did you set that?
    Also the writing on the case doesn't line up exactly with the correct pins, so it might be accidentally in an adjacent pin.
  • So apparently I can no longer trigger my camera off of pin A9. The forums new CHDK page doesn't do a good job of how to connect everything with their new revamp of pin outputs (digital vs analog).A while back, I was using this tutorial for setup and it worked like a champ. I went without for a little while and now that I am trying to get back into messing around with mapping projects, I cant get it to work. Any pointers?? My original setup was using A9 as per this thread. Now that I have re installed the camera back on A9, I get nothing. Ive tried doing what the APM forum says, using the actual RC Output channel 7, and setting it to camera trigger in the FullParamsList but still, nothing. Even tried A7..  I tried using trigger type as "relay" and "servo;" which happens to toggle a servo when I connected it. There is no "relay_pin" command anymore to activate A9. Im kinda at a loss here.. help??
  • wth happend to the camera_tiggger_dist and Relay_pin parameters??? They arent showing up anymore. Did they get removed from the full param list?
  • That's right, its resolution is 10ms at best. I have Ch. 7 of my transmitter coupled to the relay switch of the APM though. This way when you apply a high pwm value, the relay pin remains set. I used that previously to turn off the camera before landing so that I have better lens protection. If you need more commands you get the complexity of timing by hand how long the switch should be on and there's not an easy way to check whether the command was actually applied from the ground.
    That could be an interesting feature for the APM, to translate a pwm value to a pin 'on' duration.
