[UPDATE: This project is now being ported to a proper Google Code repository and manual. For instructions, start there. You can also join the ArduRover User Group here.]
Hello to ALL, the new firmware for APMRover v2 has been tested successfully on my rover on may 1st, 2012 on full autonomous reco mission following a navigation plan. This new release of the APMRover v2 works on the APM v1.4 with the OilPan shield (magnetometer + MT3329 GPS) and also of course on the APM v2. The previous version of the APMRover v1.0 was a light size version specially designed for the APM1280 CPU (only) board and the MT3329 GPS.
For the frame, I have used a Traxxas Monster Jam Grinder with a brushed and high power motor Titan 12T and its XL-5 ESC.
The APMrover UGV is able to run itself following a list of recorded waypoints. The waypoints list (FPL) can be preloaded with the APM Mission Planner OR better in live, recorded by the pilot himself (with the SW7) during a manual run and then replayed in a full autonomous mission.
The firmware APMrover2 for APM v1 + OilPan or APM v2 successfully tested can be downloaded HERE
The APMrover v2 is also online on the official ArduPilot-Mega GIT repository HERE
Below the PID setup for the APMrover v1 and v2:
The light firmware APMrover1 for APM v1 (CPU 1280 or 2560) that I have tested can be downloaded HERE
Here's how to connect your cables:
More infos at: http://diydrones.com/profile/JeanLouisNaudin
Have Fun and Enjoy with the APMrover...
Regards, Jean-Louis
Earl
You will find the details of the update about the APMrover v2.1.3a in my GIT repository at:
Revision:9bd6dda3bbf8
Regards, Jean-Louis
Hello Franco,
The new release is done at:
http://ardupilotdev.googlecode.com/files/APMrover213_firwmare.zip
I have put an offset at 50% throttle so this equal to zero for the ESC...
0% = full backward, 50%=stop, 100% is full forward...
I hope this will work now...
Good testing
Jean-Louis
Hello Franco,
Thanks for your very helpful test report from the field. I see where the bug is located...This is due to the bad offset of the throttle... I have forgotten that the zero throttle was in the middle (50%) and not to zero (0%)...
I shall correct this and it will soon works...
Regards, Jean-Louis
Hi jean-Louis,
thank you!
Yes, it was a jolly mission.
But...I have to share this achievement with you.
Merci pour votre travail.
Best regards.
MV
Hello,
For those have already tested successfully the APMrover v2.1.2 and doesn't want to change the working library and want to test the new method for increasing the throttle which gives a smooth acceleration, you will find the new v2.1.3a with this feature at:
This can be done with the parameter THR_SLEWRATE
#defineTHR_SLEWRATE 1 // if set to 1 the throttle increase is by 0.1 steps, if 0 it is disabled
I recommend you to try 1, this gives a step of 0.1. Only positive values must be used, you may try 1, 2 ,5, 10... if you put 0 the throttle management is like the previous version v2.1.2.
Regards, Jean-Louis
Hello MVeloso,
Woow, Congratulations you navigation plan is impressive and I am very glad to see that you have done a successful test of the APMrover.
Good work, Jean-Louis
so this was the plan:
and this is the video:
It worked fine. But some corrections to do.
I had only my little GoPro but you can have a good ideia about the test.
https://www.youtube.com/watch?v=_k_j0UxmiMk&feature=youtu.be
Hello TCIII,
Good idea to use an external board for obstacle avoidance, you may send infos to the APM through the analog input which is actually used for the sonar.
Regards, Jean-Louis
Hello Franco,
You will find a new alpha version APMrover v2.1.5 for testing: This version use a new method of increasing/decreasing the throttle with the THR_SLEWRATE, I recommend you to try 1, this gives a step of 0.1. Only positive values must be used, you may try 1, 2 ,5... if you put 0 the throttle management is like the previous version v2.1.2.
You will find this new ALPHA version at:
http://ardupilotdev.googlecode.com/files/APMrover215_new_mavlink.zip
Please use the library included, this is the new latest library with the uptodate mavlink lib from the official GIT.
Happy testing,
Jean-Louis
19
20
21
22
23
of 36 Next
