[UPDATE: This project is now being ported to a proper Google Code repository and manual. For instructions, start there. You can also join the ArduRover User Group here.]
Hello to ALL, the new firmware for APMRover v2 has been tested successfully on my rover on may 1st, 2012 on full autonomous reco mission following a navigation plan. This new release of the APMRover v2 works on the APM v1.4 with the OilPan shield (magnetometer + MT3329 GPS) and also of course on the APM v2. The previous version of the APMRover v1.0 was a light size version specially designed for the APM1280 CPU (only) board and the MT3329 GPS.
3689454489?profile=original
For the frame, I have used a Traxxas Monster Jam Grinder with a brushed and high power motor Titan 12T and its XL-5 ESC.
The APMrover UGV is able to run itself following a list of recorded waypoints. The waypoints list (FPL) can be preloaded with the APM Mission Planner OR better in live, recorded by the pilot himself (with the SW7) during a manual run and then replayed in a full autonomous mission.
3689454514?profile=original
3689454602?profile=original
3689454577?profile=original
3689454598?profile=original
The firmware APMrover2 for APM v1 + OilPan or APM v2 successfully tested can be downloaded HERE
The APMrover v2 is also online on the official ArduPilot-Mega GIT repository HERE
Below the PID setup for the APMrover v1 and v2:
3689454536?profile=original
The light firmware APMrover1 for APM v1 (CPU 1280 or 2560) that I have tested can be downloaded HERE
Here's how to connect your cables:
3689454662?profile=original
More infos at: http://diydrones.com/profile/JeanLouisNaudin
Have Fun and Enjoy with the APMrover...
Regards, Jean-Louis
    Hello Kelvin and Boris,
    The Xbee telemetry works well with the A¨PMrover, I suggest you to use the lastest version APMrover v2.20a that you will find at: http://ardupilotdev.googlecode.com/files/APMrover220_firmware.zip
    I suggest you to read the tuto about the setup of the Xbee with the APM 1 at:
    http://code.google.com/p/ardupilot-mega/wiki/APM1Wireless?wl=en
    Regards, Jean-Louis
  • Hi
    I am using APM1 (1280)+Oilpan and GPS with APMrover v2.16a firmware. Can i use Xbee for telemetry?
    @Cody: GPS need to be locked (3D fix) and the home position stored in memory to use the APMrover in autonomous navigation...
    @Ben: May ba that this is a bad memory mapping of the parameters, it is recommended to do a setup then reset with the planner (in terminal mode) when you upload a new firmware.
    JLN: Excellent--many thanks! I'll test tomorrow when I've got my gear in front of me.
    Hello,
    I have just updated the APMrover 2.20 to 2.20a with a small tuning about obstacles avoidance with the Shap sensor. If the TRACE is ENABLED you will see in the planner message that the obstacle = 1 if the distance is less than the sonar_trigger distance. In the LEARNING mode (previously named STABILIZE mode) the wheel turns left when obstacle equal to 1. This is very helpful for the tuning and the mechanical setup of the Sharp sensor.
    Ps: you must have the GPF 3D fix to get the ground_course displayed and all things working properly.
    3692443134?profile=original
    Regards, Jean-Louis
  • Dear Jean-Louis, thank you so much.
    Hello to all,
    I have just pushed the new APMrover v2.20 firmware on the GIT official ardupilot-mega repository at:
    Revision:34a4182a11ad
    Special update for the use of the RangeFinder optical SharpGP2Y sensor instead of ultrasonic XL MaxSonar (too much noisy close to the ground).
    The compilation is OK with Arduino 1.00-relax and the latest version of the GIT library see below:
    3692442709?profile=original
    Regards, Jean-Louis
    Hello Jack,
    For the mavlink telemetry test with the planner, you need to set in the APM_Config_Rover.h:
    #define SERIAL3_BAUD        57600
    I shall update this by default in the next release of the APMrover firmware.
    Regards, Jean-Louis
    Thanks!!
