ArduCopter 3.2 Released
ArduCopter 3.2 (aka APM:Copter) has been released as the default version replacing AC3.1.5. This is the exact same version that we invited all users to test two weeks ago.  Users who wish continue using AC3.1.5 can find it under the "Pick previous firmware" version on the MP's Install Firmware screen.
The full list of changes can be found in the ReleaseNotes but here are the highlights:
Flight Mode Enhancements:
  • PosHold flight mode: similar to Loiter but with direct response to pilot input during repositioning
  • ACRO mode handling improvement EXPO (for faster rotations)
  • Drift mode uses "throttle assist" (similar to AltHold)
  • Smoother transitions between flight modes (i..e when entering Loiter or RTL from high speeds)
Mission Enhancements/Fixes:
New Sensors/Devices:
Safety Features:
  • EKF/DCM check will switch to LAND mode if heading error > 60deg for 1 second
  • Baro glitch detection
  • Pre-arm check for Gyro calibration success
  • Pre-arm check that internal & external sensors (gyros, accels and compass) are consistent (Pixhawk only)
  • Parachute support (Pixhawk only)
  • Feedback to Pilot when taking off in AltHold, Loiter, PosHold (i.e. motors spin up a little as throttle is raised)
  • EKF (new attitude and position estimate system only used for reference in this release)
Bug Fixes:
  • Pixhawk GPS driver buffer overflow that could lead to missed GPS messages
  • Pixhawk I2C bug that could lead freeze up if I2C bus is noisy
Known issues/Warnings:
  • Pixhawk users will need to recalibrate their compasses
  • PosHold won't show up as option on FlightMode screen if you have an old version of mission planner. Please select Help > Check for Updates.
  • Landing detector is more strict meaning it may take longer to disarm after RTL, AUTO.
  • Set THR_MID parameter especially if you have a very powerful copter because "Feedback to Pilot" raises throttle to 1/2 of THR_MID
  • Spline twitches slightly as it passes a waypoint especially if WPNAV_SPEED is set > 500.
  • Dropped support for NMEA and SIRF GPS on APM boards (ran out of Flash space)
  • Dropped support for sonar for MultiCopters on APM1 and TradHeli on APM1 & APM2 (ran out of Flash space)
If you hit issues, please post them in the APM Forum and include a dataflash log file if possible.
Special thanks to Marco and the Beta Testing team from the AC3.2 beta testing thread who put their copters at risk in the pursuit of a smooth, safe release. Here are links to some of their videos: Marco's DJIs900, Holger's Water Tower, Josh's Acro, Ray's TradHeli2&FPV, Raph's Hawaii, PhillS's CommandYaw, Thor's Zombie Run&FollowMe, Phanivyas's Test, Rob's TradHeli, Christian's Test1&Test2, Balloon's Spline, JimJ's FPV, Ultrojo's ROI & Spline&FollowMe1&FollowMe2, Troy's Mission
Thanks also to the code contributors to this release including Tridge, Jonathan, Leonard, RobL, Paul Riseborough, MichaelO, Julien Dubois, David Dewey, Andrew Chapman, Emile, Allyson and many more. If you want to get involved check-out our dev wiki.
    Hi Richard Kennedy,
    the parameter you are looking for is WPNAV_SPEED in loiter. You will get an acceleration of 7.5m/s/s (around 30 degrees).
  • Can someone please explain the function of IMAX . I see values from different sources showing values that vary between 5 and 1000 ?
  • Hi Team, I have a question re autotune, I fly a 12 pound camera X8 setup am I better off Autotuning under full load(With Camera onboard) or Autotuning without?
  • Randy
    On another topic I see Pilot_VelZ_max  ... why isn't there a Pilot_HorZ_max? That is to say I'm trying to still have the aggressive max 45 degree pitch forward however the quad will soon be going much faster than I'd like and much faster than the baro likes to deal with. If I manually control it to keep it under 15 mps or so it's fine. But that's sort of labor intensive to keep the stick in the exact spot. It would be nice if I could push it full forward and know it would max out on it's own at 15 mps yet still get the 'hole shot' acceleration the 45 degree pitch forward allows. I tried the dual rate on my TX but that really doesn't do the trick it kills the hole shot and still goes above 15 mps it just takes longer. Sorry for the question I don't see anything in the wiki or the full param list mentioning any max horizontal speed for pilot controlled flight only guided. Am I missing it? Thanks
    @Richard, sounds like you've certainly taken enough care of the compass so surely it's fine.   In my limited experience with the 4-in-1 ESCs, their interference is less than individual ESCs.
  • Randy
    Thanks.  So if the compass was too close to a motor or esc that would be reflected by the interference data? It does seem to fly fine. I recently changed to one of those all in one esc's and it's only 1 cm or so away from the pixhawk. I bought this rather expensive EMF shielding spray and some copper foil. I used both to separated the controller from the all in one esc. It seems to work well. The gps and compass are above the esc as well. If I watch the HUD compass heading and go full throttle I don't see any movement. Not a real sceintific measuring system but it stands to reason that's the real end game.  But when I saw that warning I was wondering. 3701886016?profile=original
  • @Randy thanks i got it! and answered you back thanks again for the stellar work!!
    @Thor, I've sent you my email address.
    @Richard, So there are two problems reported there.  The first one, is the high Z-axis compas offset which I don't think you need to worry about.  We've actually recently modified the log analyser to be consistent with the flight code so that it checks that the overall length of the three together is less than 500.  So with the latest log analyser that offset wouldn't be flagged as an issue.
    The large mag field is probably ok as well.  It's hard to know without looking at the logs but it's either that your location on the planet has a strong mag field or there is some short-term interference that's been caught by the check.  The interference number is really the most important thing and it's very low at 9.27%.  I'd say if the vehicle is flying ok, then it should be fine.
  • Randy or anybody who knows
    Is this the external compass aka compass 0? Is this really bad? Could this be what has cause a GCS warning "EKF variance'"then "mode land"? I have the gps / compass on a pedastal not sure what more I could do.3701886259?profile=original
  • @Randy how can i ping you? i have my log ready to upload but this page doesnt offer an option to add a file?
