Ardupilot Ground Station 2.6.4 A&B New Look
Hi All,
Been hanging around here for quite a while now and gleaning as much information as i can, maybe its time to give something back.
One of the biggest problems we found was that when in the field, its hard to get all the information where you need it, re-sizing all the windows, if you touch the pad, you can lose the window you want, always the GS, hard to find the pointer to bring it back, when you have one eye on the aircraft one eye on this...
So this is my attempt..
I hope its usefull to you.
Please give feedback as to you thoughts and any improvements.
GROUND STATION 2.6.4 UPDATE::
1024x768 GCS for smaller Laptops
True speed indicator updated for greater accuracy
You can set True speed to MPH/KMH (defaults to KMH) & Altitude to Meters/feet (default Meters)
Tme Left estimator, a better accuracy with a new gauge. (you need to set Amps FT to what your aircraft draw flat out)
Amps / Watts added (again needs to be set up bottom left with your cell count and Mah)
Complete colour re-design for ease of view outside, on a sunned out dull laptop.
THINGS TO DO:
Fix the irritation, when you click the FIND UAV button so that it auto pops to the position, at the mo you have to double click the position in GE then the GS rotates to where it needs to be. STILL NOT FIXED
Flight trackin. STILL NOT FIXED
Sorting some innacuracies with Time estimator. BETTER
AP Mode being added on 265
Enjoy.
Try MY Version GE and DONT update it!!!!! this might solve the GE window fro a couple of you guys....I know that GE changes the Callin API about as often as they change underware........so has been a problem fro all integrators...however as i said before in NOT a programmer, 30 years as an aerodynamcist aircraft designer, and 4 years as a military field asset, so please forgive my crude programming.
Thanks to the 'Crashing Dutchman' for updating the look and feel.
GCS264a Source.zip
GCS264a.zip 1024/768 resolution
GCS264b not uploaded yet
GoogleEarthWin.exe
LV 8.5 or 8.5.1 works available by google search or just in the last line of top of this page : Runtime or
8.5 is Here (thanks Morli)
Doc.
Comment by Chris Anderson on November 13, 2009 at 12:45pm
Mike, now that I've had a chance to play with this, all I can say is bravo! I'll talk to Jordi about making it the official version, if you don't mind...
Comment by Dr Mike Black on November 13, 2009 at 1:02pm
Chris, be my guest, it would be an honour!!!!!!
There are some more improvements coming, but had enough coding by 1am last night.
Also there is a bug in calling the position on GE to where you actualy are, the trick for the moment is to click teh 'UAV Location' button, then goto GE and double click the ardupilot icon that comes up in the left of teh screen, it then takes teh GCS to where it should be....annoying but not awfull, will work on that some more...
Also shrink GE to a small screen that way the globe fits the window...another annoyance, but hopefully we can fix thsi also...when i get to my pc i WILL upload the source...
If there are any changes or improvements you guys can think off let me know....
Comment by Morli_ on November 13, 2009 at 1:54pm
It is running for me ver8.5 run time but the google earth part of screen detaches from GCS screen if you click on run or run continuously button
Comment by Dr Mike Black on November 13, 2009 at 2:04pm
Morli,
woooo, thats a new one......try installing the new runtime engine...as i had this start with, but when i updated everything it worked ok...just a thought...
Comment by Dr Mike Black on November 13, 2009 at 2:06pm
Also closing and re-opening GE can also sort this....erm.....i think....lol
Comment by Chris Anderson on November 13, 2009 at 2:25pm
Mike, you might want to edit your post to include a link to the runtime.
Comment by Morli_ on November 13, 2009 at 11:18pm
Hi Chris,
The original GS did not run either in the older or newer LV runtimes( tried 8.5, 8.6.1. or 2009) , it runs only on 8.6.1( as recommended ). this ver runs with 8.5 ver( checked by clicking on "about" in GS of LV in my laptop. There are few issues( e.g Earth google control buttons don't respond) in this ver of GS that I noticed but they don't seem to be related with runtime IMHO
Comment by Saiful Azuwan on November 14, 2009 at 1:36am
@Dr. My GCS don't show the GE
Comment by Earl on November 14, 2009 at 2:06am
I like it. Haven't tried it yet as I am working on new SW for the ArduStation Box.
Earl
Comment by Riccardo Kuebler on November 14, 2009 at 2:29am
Dr,
niiiice, it works for me (at home). I have to restore my Ardupilot (plane) to try it in flight.
Best regards,
Ric
Comment
