ArduPlane home page
3689354430?profile=original
3689312509?profile=original
Convert any RC airplane into a fully-autonomous UAV!
Just add the APM 2 autopilot to any RC aircraft and it becomes a fully-programmable flying robot with a powerful ground station and Mission Planner.
Features include:
  • Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
  • Unlimited 3D GPS waypoints
  • Built-in camera control
  • Fully-scriptable missions
  • One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
  • Replay recorded missions and analyze all the data with a graphing interface
  • Supports two-way telemetry with Xbee wireless modules.
  • Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
  • Fly with a joystick or gamepad via your PC--no need for RC control!
  • Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
3689354391?profile=original
3689354242?profile=original
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
*  APM 2.5 autopilot with GPS ($179)
*  [Optional] Telemetry kit ($75).
3689354459?profile=original
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies!3689354440?profile=original (We're partial to the SkyFun delta wing (right) and
Bixlee 2   powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
  • @Martijn
    I just went through the same process.
    ArduPilot Mega
    Mega IMU ( the $150 ver that comes with the correct pin headers)
    3x8 Right Angle Pin Headers(qty 2)
    Ublox, Ublox adapter, Adapter cable
    Servo extensions( to connect the mega to your RC receiver)
    Air Speed Senor Kit MPXV5004DP
    I think that should be everything you need to get going
  • You will need a Ublox and Ublox adaptor and Ublox ext cable.
    For airspeed sensor, you will need the breakout board and sensor.
    (thats if the code used supports it)
    Eveything is slowly coming together, it takes time, there might be a slight change in the code that changes everything, so right now it hard to say what you will need and what you should order till it goes a little further.
  • @Martijn. Personally I think that the DIYDrones store is organized very well as well as the forum. You can do a simple search of the site and you can find just about anything you want. And all of the manuals are right on the header tabs of the website. You might want to check your resources and do a little bit more exploring before you accuse diydrones of being un-organized. They only have so many moderators and there are 10,000+ members. Naturally with any business, you can't please everyone.
  • Hello everybody !
    I have already received my processor board, and the shield will arrive next days...
    Please, do you have schematics for the shield board (if possible in pdf format ?)
    I would like to study the datasheets & prepare my software !!!
    Thanks a lot & best regards,
    Gilles
    @Dave. We probably will support the EM406 eventually, but it's not our top development priority at the moment and I don't think anyone on the dev team still uses one. I'd look for it in the second round of releases.
  • @Chris - forgot - are you recommending ONLY the UBLOX GPS for now? I still have an EM406.
  • @Chris. Thanks much - Best Wishes! Fantastic Effort!!!!
    @Dave. Manual is updated with a link now.
    Digxx, we'll release all that with the code. Right the more we say the more questions we get, which just grinds development to a halt.
  • @ Dave
    I think this is what you're looking for
