Features include:
- Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
- Unlimited 3D GPS waypoints
- Built-in camera control
- Fully-scriptable missions
- One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
- Replay recorded missions and analyze all the data with a graphing interface
- Supports two-way telemetry with Xbee wireless modules.
- Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
- Fly with a joystick or gamepad via your PC--no need for RC control!
- Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
* APM 2.5 autopilot with GPS ($179)
* [Optional] Telemetry kit ($75).
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies! (We're partial to the SkyFun delta wing (right) and
Bixlee 2 powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
The speed 115200 is used only at the USB/FTDI port.
Xbee you will attach on TelemPort (IMU Shield/Oilpan)
Please, more infos here: http://code.google.com/p/ardupilot-mega/wiki/Wireless
GPS on APM GPS Port
More info here:
UBLOX: http://code.google.com/p/ardupilot/wiki/ublox
MediaTek: http://code.google.com/p/ardupilot/wiki/MediaTek
In current download of ArduPilotMega?_1_0_1 and in all revisions since that I can see. the file APM_Config.h is setting the baud rate of Serial1 and 3 to 115200.
But according to the docs its saying to use X-CTU to set it to 38400... Also according to the Ublox docs has been 38400 as well.
So should we be setting ublox and xbee's to use 115200 or change config to 38400 for Serial 1 and 3?
my config is an APM Beta w/oilpan, ublox, mag, airspeed, and xbee pro (900)
http://code.google.com/p/ardupilot-mega/wiki/RC
APM wants to see the throttle channel, and control motor speed, so you should connect the ESC to APM.
Thanks I know it's frustrating and you'd like to get started right away, but you'll have a much better experience if you can wait another 3-4 weeks.
Init ArduPilotMega 1.0.1 Alpha
min / max from eeprom -1 -1
Offsets -0.00 -0.00 -0.00 -0.00 -0.00 -0.00
##FBW A
XXX Startup: AIR
XXX invalid home position
The GPS came in NMEA mode and I tried to switch it using
void setup()
Serial.begin(38400); // FTDI on APMega
Serial1.begin(38400); // GPS port on APMega
Serial.print("Begin GPS Mod");
Serial1.print("$PGCMD,16,0,0,0,0,0*6A\r\n"); // Custom binary protocol
//Serial1.print("$PGCMD,16,1,1,1,1,1*6B\r\n"); // NMEA
void loop()
// Incoming from GPS
if(Serial1.available()>0) //Ok, let me see, the buffer is empty?
delay(30);
while(Serial1.available()>0){
byte incoming = Serial1.read();
//Serial.print(incoming,DEC);
Serial.print(incoming,BYTE); // will output Byte values
//Serial.print(",");
//Serial.println(" ");
If I put it back to NMEA mode I can use the NMEA test program and read
GPS NMEA library test
GPS: Time:22241000 Fix:1 Lat:392611900 Lon:-768347733 Alt:110.20 Speed:0.00 Course:0.00
GPS: Time:22241100 Fix:1 Lat:392611900 Lon:-768347733 Alt:110.20 Speed:0.00 Course:0.00
GPS: Time:22241200 Fix:1 Lat:392611900 Lon:-768347733 Alt:110.20 Speed:0.00 Course:18.40
GPS: Time:22241300 Fix:1 Lat:392611900 Lon:-768347733 Alt:110.20 Speed:0.00 Course:18.40
GPS: Time:22241400 Fix:1 Lat:392611900 Lon:-768347733 Alt:110.20 Speed:0.00 Course:18.40
GPS: Time:22241500 Fix:1 Lat:392611900 Lon:-768347733 Alt:110.20 Speed:0.00 Course:18.40
GPS: Time:22241600 Fix:1 Lat:392611900 Lon:-768347733 Alt:110.20 Speed:0.00 Course:18.40
GPS: Time:22241700 Fix:1 Lat:392611900 Lon:-768347733 Alt:110.20 Speed:0.00 Course:18.40
GPS: Time:22241800 Fix:1 Lat:392611900 Lon:-768347733 Alt:110.20 Speed:0.00 Course:18.40
GPS: Time:22241900 Fix:1 Lat:392611900 Lon:-768347733 Alt:110.20 Speed:0.00 Course:18.40
GPS: Time:22242000 Fix:1 Lat:392611900 Lon:-768347733 Alt:110.20 Speed:0.00 Course:18.40
GPS: Time:22242100 Fix:1 Lat:392611900 Lon:-768347733 Alt:110.20 Speed:0.00 Course:18.40
GPS: Time:22242200 Fix:1 Lat:392611900 Lon:-768347733 Alt:110.20 Speed:0.00 Course:18.40
GPS: Time:22242300 Fix:1 Lat:392611900 Lon:-768347733 Alt:110.20 Speed:0.00 Course:18.40
GPS: Time:22242400 Fix:1 Lat:392611900 Lon:-768347733 Alt:110.20 Speed:0.00 Course:18.40
GPS: Time:22242500 Fix:1 Lat:392611900 Lon:-768347733 Alt:110.20 Speed:0.00 Course:18.40
GPS: Time:22242600 Fix:1 Lat:392611900 Lon:-768347733 Alt:110.20 Speed:0.00 Course:18.40
GPS: Time:22242700 Fix:1 Lat:392611900 Lon:-768347733 Alt:110.20 Speed:0.00 Course:18.40
GPS: Time:22242800 Fix:1 Lat:392611900 Lon:-768347733 Alt:110.20 Speed:0.00 Course:18.40
GPS: Time:22242900 Fix:1 Lat:392611900 Lon:-768347733 Alt:110.20 Speed:0.00 Course:18.40
GPS: Time:22243000 Fix:1 Lat:392611900 Lon:-768347733 Alt:110.20 Speed:0.00 Course:18.40
hElP Am I stupid or what?
41
42
43
44
45
of 59 Next
