ArduPlane home page
3689354430?profile=original
3689312509?profile=original
Convert any RC airplane into a fully-autonomous UAV!
Just add the APM 2 autopilot to any RC aircraft and it becomes a fully-programmable flying robot with a powerful ground station and Mission Planner.
Features include:
  • Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
  • Unlimited 3D GPS waypoints
  • Built-in camera control
  • Fully-scriptable missions
  • One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
  • Replay recorded missions and analyze all the data with a graphing interface
  • Supports two-way telemetry with Xbee wireless modules.
  • Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
  • Fly with a joystick or gamepad via your PC--no need for RC control!
  • Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
3689354391?profile=original
3689354242?profile=original
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
*  APM 2.5 autopilot with GPS ($179)
*  [Optional] Telemetry kit ($75).
3689354459?profile=original
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies!3689354440?profile=original (We're partial to the SkyFun delta wing (right) and
Bixlee 2   powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
    Instructions on dehosing the PPM encoder (or just updating the firmware) are here.
    You should always be able to recover the encoder via ISP, unless you have totally hosed the fuses.
  • Has anyone had a PPM encoder update go bad? and how to recover or is the APM bricked? (AVRISPMKII via 328 SPI)
    Earl,
    All APM bugs should be reported in the Issue Tracker.
  • Where to report bugs in version 706 ?
    Earl
    Just to note that if you follow the current Checkout instructions, or explicitly check out
    http://ardupilot-mega.googlecode.com/svn/Sketchbook/trunk
    you will have a fully-populated Arduino sketchbook that will build APM (yes, you still need to configure for your GPS, etc.).
  • Yes, go to the main sketch page, and use these includes.
    //GPS
    //#include // ArduPilot IMU/SIM GPS Library
    //#include // ArduPilot MTK GPS Library
    #include // ArduPilot Ublox GPS Library
    //#include // ArduPilot NMEA GPS library
  • Does the latest code from the SVN trunk require some removal of comments to enable communication with the uBlox GPS from the DIY Drones store?
    I can get the GPS to communicate fine using the older 1.0 code, but not yet with the new code.
    Just wondering what I am missing.
    Thanks for any suggestions
  • @Chris
    I have seen the error of my ways. It helps if you download all of the files.
  • Occam-pi and Plumbing?
    Parallel processing on the Arduino Mega using the standard IDE. Have you gurus had a look at this yet?
    I only bring this up as you have already thought ahead and planned a hierarchy for the commands which could be used to thread the tasks. Although its benefits of two threads could be outweighed by the speed of a highly optimised single thread on such a microcontroller. Just a thought for the gurus :)
