ArduPlane home page
3689354430?profile=original
3689312509?profile=original
Convert any RC airplane into a fully-autonomous UAV!
Just add the APM 2 autopilot to any RC aircraft and it becomes a fully-programmable flying robot with a powerful ground station and Mission Planner.
Features include:
  • Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
  • Unlimited 3D GPS waypoints
  • Built-in camera control
  • Fully-scriptable missions
  • One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
  • Replay recorded missions and analyze all the data with a graphing interface
  • Supports two-way telemetry with Xbee wireless modules.
  • Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
  • Fly with a joystick or gamepad via your PC--no need for RC control!
  • Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
3689354391?profile=original
3689354242?profile=original
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
*  APM 2.5 autopilot with GPS ($179)
*  [Optional] Telemetry kit ($75).
3689354459?profile=original
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies!3689354440?profile=original (We're partial to the SkyFun delta wing (right) and
Bixlee 2   powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
  • I can report the same problem. Checked out the sketchbook and when trying to compile i get the following error:
    D:\utveckling\Projekt\Ardupilot UAV\APM Software\ardupilot-mega\Sketchbook\trunk\libraries\FastSerial\/FastSerial.h:53:20: error: Stream.h: No such file or directory
    D:\utveckling\Projekt\Ardupilot UAV\APM Software\ardupilot-mega\Sketchbook\trunk\libraries\FastSerial\/FastSerial.h:86: error: expected class-name before '{' token
    D:\utveckling\Projekt\Ardupilot UAV\APM Software\ardupilot-mega\Sketchbook\trunk\libraries\FastSerial\/FastSerial.h:106: error: 'Stream' has not been declared
    /Magnus
  • @Chris and Michael
    I got the libraries via svn checkout of the arducopter trunk you gave. Now I get a compilation error of a missing file called stream.h. I searched through the libraries and the file is nowhere to be found. Do you have any suggestions on where I can get the stream.h?
  • Chris and Michael,
    Thank you for the info. I will check those places. I really appreciate it.
    The libraries zipfile is out of date. For easiest building, check out the Sketchbook.
    Libraries are all here.
  • Another quick question... In the latest code available for checkout, there is an include for FastSerial.h, but I cannot find it anywhere in the libraries.zip or on the svn trunk. It is causing a compilation error because it is missing.
    Is there another place that I can get that file from?
  • I am attempting to use my APM on an aircraft powered by an IC engine instead of electric. The vibration from the engine seems to be affecting the sensors on the APM. For example, when the engine is throttled up while the aircraft is stationary and the APM is in stabilize mode, the control surfaces will begin to respond as if they are counteracting roll or pitch that is not actually taking place.
    Does anyone have any suggestions such as additional filters (software or hardware) or something else that will help the APM not to be affected by the engine vibration?
    No, I think you're right. I had naïvely assumed that all of the SPI devices were sharing a single bus, and the schematic makes it hard to follow this sort of thing.
  • Thanks Michael,
    I thought that port 2 was being used by the oilpan in SPI mode. Is this incorrect (I'm pretty new to embedded harware/software so I could definitely be wrong)? It looks like it is just being used to send the IMU data as well as the differential pressure, so if this is the case I guess I could still use port 2 since I don't need the IMU data and just read the differential pressure on an analog input on the mega?
    You should be able to use port 2; IIRC it's on the oilpan headers but not connected to anything.
