Features include:
- Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
- Unlimited 3D GPS waypoints
- Built-in camera control
- Fully-scriptable missions
- One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
- Replay recorded missions and analyze all the data with a graphing interface
- Supports two-way telemetry with Xbee wireless modules.
- Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
- Fly with a joystick or gamepad via your PC--no need for RC control!
- Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
* APM 2.5 autopilot with GPS ($179)
* [Optional] Telemetry kit ($75).
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies! (We're partial to the SkyFun delta wing (right) and
Bixlee 2 powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
Connect your 5V supply to one of the servo connections on APM. Make sure you don't reverse the connection. Enjoy!
Loti
As for short circuits, what about them specifically?
@james - check your soldering carefully. If you have access to a multimeter, you can try watching the 5V rail at e.g. the telemetry connector on the oilcan to see whether you have obvious power supply issues.
Do you have servos connected when you are experimenting with the board? Many of us have had problems with the USB power not being sufficient to support any servos connected to the board - you will need additional power via a BEC or similar in this case.
I can't find in the manual the way to power the APM+IMU with an external power source.
I want to use a 5V or a 3.3V instead of an external battery + BEC, which is the correct way to do so and
have the APM connected to the computer with the USB port ? I suppose that connecting the external power source
to a servo channel will work, but what about short circuits ?
I just have my esc plugged into channel 3.
I'll dig into it some more tomorrow and see if I can find anything wrong.
