Features include:
- Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
- Unlimited 3D GPS waypoints
- Built-in camera control
- Fully-scriptable missions
- One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
- Replay recorded missions and analyze all the data with a graphing interface
- Supports two-way telemetry with Xbee wireless modules.
- Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
- Fly with a joystick or gamepad via your PC--no need for RC control!
- Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
* APM 2.5 autopilot with GPS ($179)
* [Optional] Telemetry kit ($75).
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies! (We're partial to the SkyFun delta wing (right) and
Bixlee 2 powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
some of the answers are in a recent arcticle on the wiki http://code.google.com/p/ardupilot-mega/wiki/Onboard
waypoints, channel to use etc.
Brett
i have the built the arducopter board and i have a quick question about flight
i was wondering if there is anyway to make the quadcopter with the Arducopter completely autonomous?
if so, is there a way to switch back to manual mode during flight if needed?
Are there any flight sensors needed for a quadcopter in order for the autopilot to work?
Thank You
I think I'm soon ready to try APM in my airframe, eg. Stabilize, Fly by wire modes.
I have done some testing with 1.0 Beta, and its looks usable.
I am using the whats available now with Legacy, although are having a few problems with the ArduPilotGCS-B2, the log file is 'temperamental', it doesn't like to shutdown and although GPS data in is good, GE doesn't seem to track (more likely a GE setting.....). That said I haven't had much of a chance to play around with it.
Yes Micheal I have loaded up ArduStationM and have a play, the only issue there is my lack of C/C++ skills. From what I understand with that one is it's up to me to determine what data I want to use and code accordingly??
Anyway, 'soon' sounds good.
Thanks guys.
George
14
15
16
17
18
of 59 Next
