Features include:
- Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
- Unlimited 3D GPS waypoints
- Built-in camera control
- Fully-scriptable missions
- One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
- Replay recorded missions and analyze all the data with a graphing interface
- Supports two-way telemetry with Xbee wireless modules.
- Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
- Fly with a joystick or gamepad via your PC--no need for RC control!
- Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
* APM 2.5 autopilot with GPS ($179)
* [Optional] Telemetry kit ($75).
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies! (We're partial to the SkyFun delta wing (right) and
Bixlee 2 powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
I am running the 12/27 version of the APM ziped software..
Xbee to ground Xbee at 38400
er9x transmitter displaying GCS data.
I have a heck of a time to get the GCS data to work on powerup on the first try. In fact, it takes many tries to get it working.
I have the latest MTK FW in the GPS.
I even tried to watch the data by removing the xbee and watching the data from the APM directly.
I get 6 to 9 lines od data then the data stops. GPS lock light stays on and the red led on the APM is on.
Any ideas ????
Earl
I have a question to ask. I have use a joystick on the ground station to control 2 servos for camera mount that is connected to APM out 4 and out 5. It is transmitting by Xbee using baud rate at 38400(is it correct?). I use C# to 2 sets of value over to APM Xbee. It is able to move smoothly with no vibration.
But when I compile the code with ArduPilotMega beta code. Its kept on vibrating. Anyway to reduce the vibration?
From the APM Manual:
Note: in the 1.0 Beta code there is a slight bug in the MediaTek setup routine, which requires you to reset your board after a cold start before the GPS lock will be registered. So if you're using the MediaTek GPS, wait until the blue lock LED on that module goes solid, then press the reset button on your APM board or shield. This will do a warm start of the board, and the LED behavior should be as shown in the table above.
12
13
14
15
16
of 59 Next
