3689462974?profile=originalSo I have some vacations coming up and already have some quads and a hex I figured I needed a fixed wing to round out my aerial camera fleet. (for now) heh. So I took the plunge and picked myself up an X8 to fill up with electronics.
3689463094?profile=original
I'm running an ArduPilot Purple, with a Castle 75 esc waiting for Hobbyking to drop of my new Scorpion motor until then I have a 700W max 50Amp local hobby store motor to power the bird. I'm running 1.2 video feeding through MinimOSD with a Sony 720 line mini cam. I have a roll and tilt GoPro mount in the works that I'll post up some pics when I can get some play time on the  router this weekend. Communication is done through a Futaba 10C 72Mhz and some 900Mhz XBees.
3689463151?profile=original
I've only made a few mods for now like adding a second motor mount plate that bolt through the foam to the outer plate.
3689462999?profile=original
I made some electronics trays and filled in the lower camera cut out with some foam and Gorilla glue.
3689463160?profile=original
3689463274?profile=original
I ended up bringing the control linkage up through the wing, leaving it on the bottom seemed like a bad idea for a belly lander. I have never flown a or built a fixed wing, but I said the same about the multirotors and DIYDrone's gear and community made it simple, awesome and enjoyable. Only crashes were ah-hem user error. So I'm hoping for the same luck with this bird. I do have tons of hours now on RealFlight sim just to make sure I feel comfortable with the controls. That being said any input from from you guys will be greatly appreciated. I'll update this blog as things progress and as I get the camera mount going. But for now heres some more eye candy. Be happy and safe all!
3689463229?profile=original3689463317?profile=original3689463299?profile=original3689463186?profile=original 3689463358?profile=original
  • Just building my X8 now... (eek, so excited!)
    Has anyone used either of the two circular holes either side of the nose for a pitot probe? If so, any problems and how far out does the probe protrude to not be affected by the boundary layer over the nose?
    Cheers,
    Excited Simon
  • Having a heck of a time tuning NAV PIDs... anyone make any progress with the new control loops for 2.6?
  • Can someone that achieves good results with the tuning in all weathers, send me the parameter file?
  • Tsk, tsk, just so happens that I installed a SK 3548-900 from a previous project in my X8 :-)
    Desperately trying to get it completed before the weekend !
    I find I need to fit 3 X 400mA/h 4S packs in the nose to balance the wing.
    I need to fine tune it manually, before fitting the APM.
  • in fact my actual motor is only approx  600W... and push it to 800W for 5 sec. burst...
    i would go with this one , only 174g ...best HK quality & good punch :
    http://www.hobbyking.com/hobbyking/store/__18165__Turnigy_Aerodrive...
    the 48mm is not only for power...but also to reduce prop noise (prop far away from back cowl)
  • Thanks for the answer.
    I like to lunch the X8 with catapult, to your opinion; can I reduce the motor power?
    Jeffbetts, Can you give info on the motor type?
  • I agree. I'm flying with 500 watt 780kv 13x6.5 4-cell setup and cruise around 100 watts in low wind.
  • yes 800w is ok with 3kg AUW X8... this is only for surge peak usage(take off)...cruise speed  only need 90 to 150w
  • ggtronic - So you believe that 800 watt is enough?
  • Itzik Ronen : NTM35-42 1000kv... but i would go for the 35-48 1000kv sk3 ...no need for 320g motor !... ESC is 80 but over kill...PLUSH 60 is OK... 12-6 carbon folding prop... 1x 4s5000
