AUAV is proud to announce our latest high quality PixHawk derivative - The XRacer V1. This project was developed in cooperation with Lorenz Meier, David Sidrane, Leonard Hall and many others. This board combines the latest IMU offerings from InvenSense and a large number of capabilities in a micro 36mmx36mm form factor.
Below are some pictures to peak your interest.
XRacer V1 specifications:
- MCU - STM32F427VIT6 rev.3
- FRAM - FM25V02-G
- Ultra low noise LDOs for sensors and FMU
- Sensors used - MPU9250, HMC5983 ( optional ), ICM20608 ( optional ), baro MS5611
- Connectors - GPS+I2C, RC-IN, PPM-IN, RSSI, SBus-IN, Spektrum-IN, USART3 ( TxD, RxD, CTS, RTS ), USART2 ( TxD, RxD, CTS, RTS ), FRSky-IN, FRSky-OUT, CAN, USART8 ( TxD, RxD ), ESP8266 ( full set ), SERVO1-SERVO6, USART7 ( TxD, RxD ), JTAG ( SWDIO, SWCLK ), POWER-BRICK ( VDD, Voltage, Current, GND ), BUZZER-LED_BUTTON
- MicroSD card reader
- RGB LED
- Micro USB
- ESP8266 802.11bgn ( optional )
- Dimensions - 36 x 36mm with 30.5 x 30.5mm hole grid with 3.2mm holes
- Molex Clik-Mate ( JST GH series ) connectors for easy peripheral connect.
- Full set of ready made cables for almost any peripheral module.
- Power supply - 5-5.5VDC from USB or PowerBrick connector. Soon the ACSP4 ( 36 x 36mm power distribution, current, voltage sensor with 5V/2.5A ultra low noise buck and 12V/2A ultra low noise buck ) companion will be announced.
The price and availability will be announced within a few weeks.
Thank you again for your support.
Phil and Nick
Phillip, While I had intended to buy the Xracer, I am also interested in getting another full-featured Pixhawk compatible FC that does not use connectors that have only rated life of 50 cycles... [errm..cough...DF13] and if can buy from a North American source , all the better.
I do find that generally, [for me anyways - so far], that less than half of the connectors are ever used at one time, whether it a quad or an Airplane setup, and it does seem that the XRacer is the result of 'cutting the fat' off in the right way, for most builds.
I just pre-ordered a couple ACSP4's & an XRacer. I was Interested in the AUAV-X2 Pixhawk FC , but it does not show stock.
Will it be available again?
Chris
When is the exact delivery date in December?
I just Pre-Ordered. Wondering about vibrations and mounting methods. Any thoughts anyone? Could not tell if Randy hard mounted or used foam tape.
I'd love to use this on my racing frames, but I'm using ESCs with OneShot and Arducopter doesn't support that yet.
I would purchase this board! Randy's video of the Iris convinced me.
