ArduPilot Shield Demo
I few days ago i received the first prototypes of the Ardupilot Shield. Right now they don't have silkscreen to reduce the prototyping costs, but the commercial version will do..Main goals:-On board 3.3V power regulator.-Disable the GPS before uploading new firmware automatically.-A lot of pins headers to easily attach sensors with power supply included.-Special connector for 3.3V GPS modules (including the TTL conversion).-Pressure sensor, with low pass filtering, for AirSpeed...-External reset button.-Mirrored status LED,s...-Optional power divider (analog 5) to measure battery level.
[Infrared connector at the bottom]The cost without the sensor will be around $20 dlls at beginning, soon if i order bigger batch's i can reduce the price.My ideas is to make 100 units without the pressure sensor, and another 100's with the pressure sensor (around $30 dlls price tag)... Stay tuned for more news..You can give a look to the diagram here:
[UPDATE]: Auto turnoff is not working properly on 3.3Volts GPS, so i will need to make some changes.
  • T3
    great i just ordered my system and would like to be included in your pre-order on this boad too if you are starting a list... thank you!
  • We can't go through paypal from where I work as a strict policy, so we'll be waiting for your other ecommerce solution. I'll definitely buy one personally for home use, though. Thanks for all the hard work!
  • Hi Jordi, any reason why this is not being done through Sparkfun? It seems easier for new users to buy everything at one place and everyone's going to want a shield.
    The board should arrive on may 15, i ordered red color ;-). Soon i will start taking pre-orders.
  • This is exciting news Jordi. Thanks for your efforts.
    Matt
    Going well, is finished, i just sent them to batch in high quantity's, is gonna take about of 1 weeks to start selling... We are setting up an small e commerce, but i think the first order's will be by email, paypal and i will FEDEX it.
    @MIchael you mean using the same microcontroller? If yes i don't think so, the SD data logging requires a lot of flash space.
    @MC, the sensor is differential so you don't need one static and another dynamic by law, and is good if you are flying in a range of 200 meters of altitude (more than the legal altitude of 125 meters), the tube i'm using is the one for eagle-three systems. Later i will investigate a nice sensor for absolute pressure, we may adopt the scp1001.
    @Kim Skatun right now we don't use it for many reasons, including available pins and flash space.
  • Why use analog sensors for pressure readings, the scp1001 has 17 bit resolution ...
  • Which pressure sensors (I assume you have one for static and for dynamic pressure sensor for a pitot-static system) are you using on this board? Do you have a tested pitot tube design to be used on the Multiplex Easy Star?
  • Chris & Jordi very radical in their approach. I will get one as soon as I understand more..
