Here a video of an autonomous flight with a Maxi Swift flying wing fully piloted by the firmware ArduPlaneNG v2.x R5 with an All In One Pro (AIOP) full IMU board.This is a porting of the ArduPlane v2 (v2.4+v2.5) firmware and special addons and improvements for the AIOP board that I have added.
The wind was 15 km/h gusting 22 km/h. The flight was very stable in spite of the gusty wind conditions.
3689473600?profile=original
3689473686?profile=original
Setup:
  • IMU board: All In One Pro (AIOP) v1.0 from CRIUS,
  • GPS: Crius CN-06 (Ublox NEO-6)
  • AirSpeed sensor: MPXV5004DP (from a old ardupilot one shield)
  • firmware ArduPlaneNG V2.x R5, porting of the ArduPlane v2 + special addons for the AIOP v1 IMU board by JLN
3689473718?profile=original
Flying Wing: Maxi Swift from MS Composite (1m40 wingspan)
  • brushless motor Spitz 30 850 kV, 360W with a propeller GWS 10x4.5
  • Lipo: 3S EVO25 2650 mAh
  • Receiver: Turnigy 9X8C v2
  • Transmitter: Turnigy 9x with Er9x firmware
3689473701?profile=original
More infos at: http://diydrones.com/profile/JeanLouisNaudin
  • 2 Adilson:
    Look for Ardupilot Mega tests there
    Hello Maxim,
    Thanks for your proposal, but I prefer to have two differents version, one for the planes/gliders and the other for the VTOL crafts (multicopters, helicopter). The UAV mission profiles are differents and this will overload too much the code.
    Regards, Jean-Louis
  • You really investigated ALL the SOURCES, or CONFIGS only ?
    File ArduPlaneNG2x.pde, find the string "// real GPS selection", and below you will see serial port allocations. But be sure to not interfere with telemetry on Serial3.
    Good luck !
  • You need investigate APM sources...
  • 2 Gil Mor:
    Ardupilot uses microcontroller's built-in ADC to measure some voltage ( except true APM1 with external ADC). But it can measure only between 0 and VCC, ie 5V. So, measured voltage must be divided, if it can be higher than 5V. You can buy a divider or solder it by yourself. FrSky Battery Voltage Sensor looks like right thing :-)  You'll need to calibrate it in software. And be careful while connecting to not short-circuit or overvoltage something...
  • Hi, Jean-Louis !  Grand merci for you hard work ! Just tested ArduPilotNG and found a minor bug :-((   In control_modes.pde file, update_servo_switches() function, the condition
    #if CONFIG_APM_HARDWARE != APM_HARDWARE_APM2
    is correct for original ardupilot hardware, but it includes all other controllers, even Crius AIOB and Arduino Mega with MPU6050 addon (my case). But the logic under this condition is for controllers with DIP switches only, i.e. APM 1.
    I think it will be better to write
    #if CONFIG_APM_HARDWARE == APM_HARDWARE_APM1
    WBR, Vladimir.
  • Got it working on the Multiwii Mega, just some small changes to gps definition, port speed, and changed pitot port to A1  (the MM has no A0)
    Lars
  • Great work, Jean Louis!
    I just bought one of these controllers from http://www.diymulticopter.org/ , and I don't want to be limited to multicopters. Is it possible to use your code with some minor tweaks?  I am not used to compiling stuff, but I am learning :-)
    Lars
  • I found the answer i was looking for. For everyone is still interested or google'g about Led meaning:
    http://code.google.com/p/ardupilot-mega/wiki/LED
    Cheers, Enrico,
  • Hi all,
    I just finished installing the card with the GPS and the anemometer.
    I loaded the ArduPlaneNG2xR5 sw by JLN and everything seems to work fine, so far so good.
    Now, i would like to know what the three LEDs (label A B C) means and which state corresponds to each LED.
    Thanks a lot, Enrico.
