Here a video of an autonomous flight with a Maxi Swift flying wing fully piloted by the firmware ArduPlaneNG v2.x R5 with an All In One Pro (AIOP) full IMU board.This is a porting of the ArduPlane v2 (v2.4+v2.5) firmware and special addons and improvements for the AIOP board that I have added.
The wind was 15 km/h gusting 22 km/h. The flight was very stable in spite of the gusty wind conditions.
Setup:
- IMU board: All In One Pro (AIOP) v1.0 from CRIUS,
- GPS: Crius CN-06 (Ublox NEO-6)
- AirSpeed sensor: MPXV5004DP (from a old ardupilot one shield)
- firmware ArduPlaneNG V2.x R5, porting of the ArduPlane v2 + special addons for the AIOP v1 IMU board by JLN
Flying Wing: Maxi Swift from MS Composite (1m40 wingspan)
- brushless motor Spitz 30 850 kV, 360W with a propeller GWS 10x4.5
- Lipo: 3S EVO25 2650 mAh
- Receiver: Turnigy 9X8C v2
- Transmitter: Turnigy 9x with Er9x firmware
More infos at: http://diydrones.com/profile/JeanLouisNaudin
Спасибо вам большое! Thanks for help! Working!!!
Today arrived my HK AIO board. I soldered the problematic voltage regulator's leg, and upgraded with Arduplaneng software, and I think working correctly, but I have settings problem (I'm using on a smaller flying wing): If I leave in manual mode, the elevons working similar than original controller-less state, but if I switch to stabilized mode, the elevon's travel is increased (over the mechanical endpoints). I tried decreased the all PID parameters, but the status doesn't change. I calibrated the radio properly. What is the problem, what I'm doing wrong?
Thanks for help!
Grateful thanks Sir!
I'm sorry for many question, but I'm totally beginner in Arduino. If I load in controller Sir Alex's ArduPlaneNG2xR5 file, can I disable unwanted sensors (like pitot tube sensor) in Mission Planner or need rewrite code and compile again? Thanx for help!
Adilson the one from earlier on the 1Nov page 6 here. Cheers
Thanx Gagarien! I will try, if the panel will arrive!
Any one got the gimbal function to work with Arduplaneng? I'm having issues but will investigate. I had compass issues and airspeed fluctuations and since Aleksey Kharlanov bug fix seems to be sorted. I have the Mediatek GPS and airspeed sensor, Istvan its working very well without AS sensor tested. Thanks.
Thanks for help!
Dear Jean-Louis! Thanks for development. I'd like build a smaller flying wing with AIO Pro controller and certainly ArdupilotNG firmware, minimOSD and NEO6M GPD module. Can I use these without pitot tube sensor, or neccesary the correct working.
Thanks for help!
Istvan from Hungary
People say cn06 GPS module need this config line in ARM_Config.h :
3
4
5
6
7
of 10 Next
