My plane is stock:Permax 400/6v motor with 12,5 x 11 cm propeller.
The stock version is useless for UAV and FPV.Main reason is the motor, but I also think the plane may be the culprit.Gliders may fly longer, but they go with the wind.
My Multiplex EasyStar with landing gear:
There is a reason for EasyStar lack of landing gear.The reason is its poor controling behaviour(small control surfaces and big wings)
The great advantage of sticking with this platform is that you can use the stock settings (header file) and not worry too much about PID tuning. If you are attempting autonomous takeoff and landing the program is very sensitive to tuning (again this is made clear in the code)
I've been working on this for a while (basically because I'm a pretty crappy flier) and I've found that it's not as easy as it sounds. You may want to approach this in phases - Doug Weibel has a really nice article on this.
Hope to hear good things from you.
Whilst the Easy* has many advantages it also has a number of vices, which may be made worse by the bigger props and more powerful motors. I put in a brushless motor and 6 x 4 prop. Both Easy* were always difficult to launch (I used the stock CofG) - they tended to dive at launch even though I tried different power settings. At full throttle I don't think the thrust line is right and that causes it to dive. With a small prop doing high revs I think the prop maybe be partially stalled and hence loses thrust until airspeed is established. With hindsight I wonder if a less powerful motor and smaller prop (the stock setup) might be better.
I always found flying under power they were squirrely although gliding was fine.
The other problem that killed both my Easy*s was tucking under. Applying too much power in a dive and it will not recover but go in vertically. This could be back to my first proposition that the thrust lines are wrong. No amount of elevator would pull them out.
I have also tried a Twinstar which to my mind is better, easier to launch and easy to add an undercarriage. The Tiger Trainer is a pussycat (although I did have a problem recently with major windshear coming over a treeline) quite heavy, easy to convert to electric and has quite a bit of space up front.
There's my tenpen'th
Peter
Christof has a wonderful twin boom version of the Multiplex's glider.
