Dean burn #2
For the 2nd time, we plugged the genderless micro Dean connectors in the wrong way & got an explosion followed by fire.
3689397741?profile=original
Without any gender, many a modeler has plugged 2 batteries into each other with these connectors, but why would anyone except a complete idiot say anything bad about a connector they spent $5 on?  Well, let us be the 1st complete idiot & regale the world with this new revelation.
3689397854?profile=original
3689397783?profile=original
3689397876?profile=original
This time, we got a pretty nasty burn.  The micro Dean connectors are the best connector for the job, but the lack of gender makes them Satan.  Marcy 1 has a new objective: finding a better micro connector.
  • 3692193430?profile=original
    Try this out:
    1. Push a section of heat-shrink over the battery lead with pre-existing soldered micro Deans.
    2. Mate the micro Deans to another micro Deans, perhaps the one on an ESC.
    3. Position the heat-shrink over the mated pair, such that the battery-side connector is covered and the ESC-side plug is about half-covered.
    4. Shrink the material.
    5. When the material is cool, remove the ESC-side plug without distorting or moving the battery-side heatshrink.
    6. Apply cyanoacrylate to the battery plug heat-shrink, securing the new jacket.
    7. Use the connectors as normal; do note that the connector is slightly more difficult to grasp but if done properly, this works perfect.
    Problem solved.
    -Steve
  • 3692192246?profile=original
    The winner was the 3 ohm resistor, very thin wire, & color coding.  If the test battery ever connects to the flight battery, it'll hopefully just get hot instead of explode.
    @ I.S.
    I would agree that they are for low power ops, but he has a picture of the standard micro dean connector above, so if he needs the small connector... these ones work well.  I use them to make s plugged cable for video transmitter to cam
  • I own at least 25 batteries with those and never had a problem.  The connector is already red.  Take a sharpie and color the negative side black.  If your trying to plug two batteries together they wont line up.  If I started a blog post every time I fried something I would be on the front page daily.
    Here's a link to the micro 4 pin connector. Not sure why, but I'm not loading the toolbar to allow me to add links or pictures. The four pin has one pin off-set so to allow connection only one direction. Nobody says you need to use all four.
    http://www.discounttrainsonline.com/graphics/WSD/L1241.jpg
    XT-60 are good, but can be hard to disconnect.
    A 10 amp fuse would save your wires and finger, But that would be no fun!
    I fried the ground wire in a new 1.3ghz  FPV setup last month. It looked similar to yours, burned off black insulation, I was lucky no other damage just replaced wire, and added a 2 amp fuse...
  • I like the EC3 connectors, literally just bullet holders, + the bullets can be used outside the housing.
    And they have gender.  So they're kind of like the XT 60 i guess!
    3692191998?profile=original
  • Its aright- You can now put your magic blue smoke back into your ic with sparkfun's latest product- The magic blue smoke refilling kit http://www.sparkfun.com/products/10622
    Well they are not micro but I am migrating to these XT 60s
    You can get a four pin micro dean connector that does orientation of the plug to avoid, accidents.
