Hello everyone,
I'm starting a new project branch for the ArduPilot, and I hope it will thrive. For an experiment run the DroidPlannerv0.1b.apk file on an Android Tablet (needs android v4) . Here it's a mere screenshot:
I know this it's not the first phone/tablet GCS to show up on this community (for example Bart copter-gcs, this closed-source copy, the Apple GCS by Zachary), but I'm thinking in a different approach. This is what I want to do:
- Develop a GCS for android devices, mainly to setup missions before flights.
- And to analyze logs on the field afterward flights.
- Increase the App to add in flight telemetry.
- And PID adjustment controls.
- Keep supporting the system.
- Make this easy to use and functional, so that you won't need to turn on a computer to fly.
Some great things are helping on this project:
- Google Maps Android API v2 - Which makes using Google maps in android applications more easily, and a lot faster. I also should point out that there is a nice cache function that makes it work offline (to some extent of course). But there is also the option of using a custom source of imagery.
- Cheap Android Tablets with USB host capability's.
Screenshots:
Before getting into how I think this should evolve let me show to you what I have already done. Bellow is a screenshot of the home screen where the mission planning is made. On the left there is a list of waypoints altitudes, on the center a map with the home position. On the top left a menu to change the screen and on the right some commands relative to this screen.
On the next picture there are show some of the actions on the menu, and more waypoints where added (with a different altitude). Using the "open file" action to open a real flight get's us back to the first picture in the post. (Files are loaded from a folder named waypoints on the sdcard, you can copy files generated with mission planner to this folder)
Edit: I added one more screen to the DroidPlanner App, is the Ground Control Point (GCP) screen. It's function is aid in the positioning of control points on the field for photogrammetry applications.
The operation is simple:
- Load a KMZ or KML file from Google Earth with Placemarks where the control points should be.
- Lockup your location at the blue dot.
- Go to a GCP location at a Red dot
- Drop a GCP marker on the ground
- Click on the red dot of the GCP to turn it blue, to show that that place has been marked.
- If there are more red GCP then go back to step 2.
Here is a screenshot of the GCP screen with a KMZ file just loaded.
And this is after some GCP have been placed on the field and have been marked;
How it think it should evolve:
The part I'm procrastinating is the communication interface (mainly because Bart has made it already). I want to implement first a wifi-UDP communication system redirected by some main GCS, this way the development will be easier (the USB port will be free for the programmer) and a nice mobile GCS will be left behind. Next the USB-serial-Xbee communication, I have some working demos to receive data from the serial port but these need more study.
How to develop:
First get a clone from my branch "DroidPlanner_Stable" at this link. Next download the ADT Bundle for the google SDK and eclipse. Download and import the Google Play library into Eclipse as explained here. Now you should be able to import the DroidPlanner project/compile/ and run on a android device (needs Android v4).
Edit: About the USB connection to 3DR radios, some tablets have USB host capabilities and the drivers needed to communicate to a FTDI CDC IC.This means the device can supply power via USB and Acess USB devices, for me all it takes is an USB microB to USB type A cable (like the one in the picture).
To decrease the doubts about this here is a screenshot of my tablet connected to an APM1 board accessing the APM terminal. I used a terminal app called "Android USB Serial Monitor".
As I pointed out at the start there is this file: DroidPlannerv0.1b.apk, that can be run on a android v4 phone or tablet.
Edit: I only have one Chinese 7 inch Tablet, so I don't know how it will behave on other devices but it's worth a try. Some has run the App on a Nexus7. I had some doubts because of the API key need to access Google maps data was a debug one.
About android v2.x.x devices:
Edit: There seams to be a lot of questions about v2 android devices, these will not be supported. At least not on the initial releases. Because with android 2.X there would be some problems with the Google Maps API v2, and the communication drivers (since USB host mode is supported only on version>v3 devices). I know it would be great to support everyone but that is a lot of work. I think at least for the start just focus on android 3.1 or higher. this way we can use the latest version of the maps API and have USB support.
And an android v4 Tablet is very cheap now, and that's what I think should be targeted.
Any questions or suggestions post bellow. Any problems downloading or compiling the source contact me with a message on this post.
Thanks.
Arthur Benemann
@adriano nocenzi
Just as a check, are you able to connect using this exactly telemetry board/ cable using a PC?
When you connect the telemetry board does a windows shows up asking you to use DroidPlanner?
When you click connect does it change to disconnected?
Hi guys I got a problem I'm using a nexus 7 with 3dr telemetry and USB cable, my problem is the tele connect itself but droiddplanner doesn't' have any activity
PS nexus 7 is not rooted is it important
Any washstand thanks for the great app and we appreciate all your hard work.
Joe
@Joseph
I added both issues, but I don't know when I will have time to address them.
https://github.com/arthurbenemann/droidplanner/issues/122
https://github.com/arthurbenemann/droidplanner/issues/121
I love the app... Great work.
Is there a way to zero the altitude in so that all altitudes are above ground like in mission planner? Also could you add an option to change units (altitude in feet, airspeed in Knots, ext....) I'm more use to it because I am a pilot.
Thanks and keep up the great work.
I am using a SVP android 4.0 7inch.
@stubugs
Do you mean TX mode 1/2 joystick position?
@Adam Haggerty
I didn't want to start a discussion about units. Is just that I have other things to work on DroidPlanner before that, but if you care to add an issue to github I'll do it later (or better yet if you implement it I'll add the code to the google play release).
About standards I just wanted to share this comic from XKCD (don't forget to hover the mouse over the image).
@Jared. Um really? I'm a research biochemist at a medical school, pretty sure I'm very comfortable with SI units. That doesn't mean my family or my clients need to convert units in their head while watching me fly. It's not that hard to add feet for altitude. That's really the only one I want.
@Stuart - yep. Just go to the parameters table and change RCx_DIR to be -1.
It is your opter that is wired incorrectly, are you sure you have the board orientation correct?
Hi is it possible to reverse rc channels on tablet as I have tried to fly my quad with it but couple of channel's needed reversing
Great job
Stuart
