EagleFPV-W.jpgDesigned especially for FPV (First Person View) camera flight!
This is a true FPV plane thats easy to build and comes packed with common sense FPV must-haves such as rear mounted servos for the elevator and rudder to help counter balance the additional radio gear. Other practical features include the large internal ply mounting trays for attaching large amounts of equipment in the desired position for correct C of G and of course a large canopy area, the canopy is not mounted to the frame allowing you to configure as you please.
This model is hand-launch which is easy due to combination of a large wing, and plenty of fuselage to grab a firm hold of, with the reccomended 4s power train, there will be plenty of power for the initial launch. The fibreglass fuselage is ultra tough and ideally shaped landing on grass, with a flat bottom and rear skid.
Specs:
Material: Fiberglass & Ply/Balsa
Wing Span: 1669mm (65.7")
Wing Area: 34.3" dm2
Fuselage: 1181mm (46.5")
Motor Mount Diameter: 58mm
Distance From Center of Mount to Fuse: 114mm (max prop diameter 8"]
Flying Weight: 2300g
Minimum 4 Channel, 4 x Mini servo
Price is US$ 175 (or US$ 166 if you wait about half a minute for a pop up to appear)
More information: White version or Grey version
  • Hi Im Interested in purchasing one of these planes and would like to know if it can be shipped to me in South Africa
    please
  • I got one but the vertical fin is not vertical some bent.
    Anyone know if the wing is FG too?
  • Dose any one know if the price will increase on the original  FG 168.
    Ive got one but before they brought it out with flaps. (because they have not updated there page yet with new photos)
  • I'd still like to see a FPV with a camera dome in the front. You'll have to take the canopy off on this one it seems.
    Most cctv camera boards are the same size and we all pretty much use the same two axis mounts. why not just take the FPV design a tad further and incorporate it. We discussed this a month ago I seem to recall.
  • Glad I got the 168 now!
    No, the 168 is fiberglass also.  I don't see much to like with this new one.  It does look like the 168 just tweaked a bit, and there are some things that got worse, like no fairing from the wing to the motor mount.  I certainly don't see any justification for the price jump.
  • Fiberglass versus foam probably?
