  • Get FMA Cellpro 4s or 10s charger. It's automatic and charges directly from Lipo's balance leads. No chance for anything like that. With a proper charger you can easily charge a 3000mAh battery with 3A or 1C.
    Don't go cheap on a charger and risk your home or workplace.
  • @Tony
    That is why I was paying close attention to it. I have seen battery fires before.
  • your are so lucky ...It could catch fire...
  • The charger arashi recommended is out of stuck anyway.
  • @Thomas
    Yeah I saw the US warehouse it makes my life a lot easier. The one that arashi recommended is at the USA one so I might be getting that since the one Chris recommended seems to not be available here in the US. Spending 20-30 on shipping for a order that is under 150 really sucks.
  • Taylor - Just directly to the car battery in the field and I have a 19amp  Radio shack one for home use.  I have it for Ham stuff.  I usually balance charge at home at lower amps, so you could get away with a smaller supply.
  • @arashi. What power supply did you use?
  • Admin
    Hobby King has a USA warehouse now and you can buy Turnigy LiPos from them at reasonable prices.
    Just a thought.
    TCIII
  • I can vouch for this one http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=15167
    It will charge at up to 10 amps and does everything.
    Best thing is that it is stocked at the USA warehouse and only costs $33.00
    I regularly charge my 3000+ 20c packs at 10 amps while in the field to no ill effect.  It also has a usb monitoring port that can be used with your PC.
  • @Chris
    Okay I'm getting that. Thanks.
