We have designed new full SPI IMU board for UAV or other projects. Board have this sensors
MPU6000 3x Axis accelerometer sensor and 3x Axis gyroscope sensors SPI
HMC5983L Triple Axis Magnetometer SPI interface
MS5611 Barometric Pressure Sensor SPI interface
MAX7Q GPS receiver (Avail. UART interface) avail also MAX-M5Q GPS, Glonass module
- Board Features:
- Build in ultra low noise linear LDO voltage regulator for sensosrs
- Build in ultra low noise linear LDO voltage regulator for GPS module
- Build-in on board filters, which reduce noise from motor and other high current electronics
- All sensors connected to SPI bus
- Uart interface for the GPS receiver
- UF.L Antenna connector for GPS antenna
- Battery for HOT module start
- I2C eeprom memory on board for GPS settings save inside in the module (can save setings without battery)
- Dimensions 32x23mm
- Power LED
- Time pulse LED for GPS (FIX)
Hello!
I have make this item for sell in my shop. All schematic avail after board order.
THANKS
Is it an open hardware projet? I would like to try to build one..
really nice work!!!
This board have SPI data from sensors and you can connect this board to your MCU. I try AHRS in this video
https://www.youtube.com/watch?v=4I7kUCcgtRs
Nice work CSGShop, tell us about which MCU do you have? And I would like to know about your base firmware, which AHRS or fusion sensors algorithm are you using DCM, Kalman? SPI ouputs includes Raw data and AHRS Quaternion?
This board designed for small Hammond ABS case and use double sided foam tape for fixing.
Very nice IMU board, looks like it might work very nicely with Beagle Bone Black via SPI.
A few mounting holes might have been nice.
It is missing holes, or second contacts row, to assemble it on a main board.
What is the compatibility of this board? I guess this board works with APM 2.x, right? Does this board works with Linux embedded board (e.g. Beagle Bone Black)?
Nice board.
Now if it had a tight coupled Kalman filter to merge all that data on-board it would be astonishing.
Will be ready 5-10 sets this week
