Good analysis of FAA drone rules by GigaOm
3689562240?profile=originalInteresting sentence in this GigaOm article: "While the FAA suggested in 1981 that model aircraft operators fly below 400 feet, the document was just an advisory, and two aviation lawyers contacted by Gigaom said the agency has no authority below 700 feet — for now."
Excerpt:
Airspace is sliced up into different regulatory layers from the ground unto outer space. The Federal Aviation Administration pays a lot attention to Class A — all U.S. airspace from 18,000 to 60,000 feet — where commercial planes fly. Then are the airspaces around airports, called Class B (big airports), C and D (smaller cities), that look like inverted wedding cakes and stretch up from the ground.
Drone fans, pay attention to Class G: an unregulated space from the ground to 700 or 1,200 feet, where the drones can fly below the airport tiers. Here’s an FAA image(I’ve added the arrows):
FAA Airspace
The 700 to 1,200 feet rule is distance from the ground, not sea level — so if you’re in Denver or another high altitude city, you can fly higher. Here’s a partial view of how aPopular Mechanics explainer chose to show the airspace:
FAA airspace by Popular Mechanics
“The FAA is already looking at it .. but it’s not going to happen for two years,” saidJohn Todd of Todd & Levi in New York, who noted that the number of amateur drones in the sky is growing quickly.
  • Benjamin is correct. Class G airspace is uncontrolled airspace. It is not unregulated. My family does Part 137 Flight operations (crop dusting) we only fly in Class G airspace, and we still need to deal with the FAA constantly. To understand the current laws, If you fly an unmanned plane for compensation or hire without a COA you are breaking the law in the USA. You can personally fly your RC plane or helicopter and take photos or do any number of other activities. At soon as it becomes commercial you are breaking the laws.
    For the Airspace, because only personal RC flight is allowed the FAA is allowing the AMA to set the guidelines for RC flight.
    This was an area just talked about at the NAAA convention were Gretchen West and Dr. Ken Giles gave a talk this week.
    http://www.agaviation.org/content/unmanned-aircraft-what-are-they-a...
  • I think the attorneys who told GigaOm that the FAA "has no authority below 700 feet" were off the mark.  The 2012 FMRA Section 336(a)(2) states the FAA has no authority to "promulgate any rule or regulation regarding a model aircraft" as long as "the aircraft is operated in accordance with a community-based set of safety guidelines and within the programming of a nationwide community-based organization."  The community-based organization is clearly the AMA and the AMA safety code clearly states flying below (approximately) 400 ft.  Obviously if the pilot has a COA then it is a different kettle of fish.
  • GigaOm misunderstands the definition of "controlled" in the context of "Class G airspace is completely uncontrolled".  It's true that pilots don't have to talk to or receive permission from air traffic controllers to fly in class G airspace.  But that doesn't mean they don't have to follow the rules.  The statement that the FAA "has no authority below 700 feet" is totally false and it's clear that it's false by simply simply looking at the visibility requirement regulations (true regulations; not guidelines) for pilots in class G airspace [14 CFR Section 91.155].  If the FAA had no authority, how could there be regulations for operation in that airspace?
    Regulations for aircraft operation includes minimum safe altitudes [14 CFR Section 91.119].  IANAL, but it seems like the advisory is more permissive (creates an exception) than 91.119 because, without the advisory, flying [model] aircraft within 500 ft of any person, vessel, vehicle, or structure would not be ok.
  • Good graphic. The FAA does have authority over class G. All navigable airspace is another story TBD.
  • I recently contacted my local airport (Manchester, NH) concerning the possiblity of flying a "Moored Balloon" commercially for doing aerial photograpy. They said as long as I stay below a 25:1 (1' elevation for every 25' from the airport) and followed all other rules that pertain to such activities (FAA Part 101), I'm good. They also told me that common sense goes a long way and don't let anybody (PILOTS) complain.
    Unicom frequencies are only available to licenced pilots (and quite rightly so speaking with my licenced pilot hat on)
    ADSB is the way to see other aircraft, although the manned community is pushing back against this. I feed ADSB data into the Flightradar 24 site using a $20 USB dongle and a bent bit of wire. If lots of us did this world wide we would have much better low level coverage and a useable avoid system. Manned aviation will have to come to the party its best UA drive it.
    For now in America seeing if you can pass a class 2 medical would be a good idea as that is going to be the first requirement. The next one is making sure you have no issues with DHS.
    Trappy is being charged for reckless endangerment not altitude issues. In particular flying in and around people without their permission.
  • Rule 1 for VFR is see and avoid.  A radio/unicom frequencies at uncontrolled fields is for announcing to other pilots your intentions like "entering the pattern", "turning base", "final".
  • Some more history behind this 'guideline'. :
    http://amablog.modelaircraft.org/amagov/2012/03/08/your-questions-a...
    It seems to me that the 400ft rule is more inspired by Minimum Safe Altitude rather than airspace separation. As the AMA states, it's not always a practical limit and it's often violated.
    Contrary to what the article loosely implies, class G is not empty. You'll find manned sport aircraft flying at usually > 500ft AGL and in sparser areas these could well be lower. Something to keep in mind when planning and executing flights.
    Your questions answered-The 400 foot limit for model aircraft.
  • If it is true that the FAA has no authority below 700 feet (except as shown in the immediate vicinity of airports), how is it that they are currently legally prosecuting Trappy or threatening other drone operators with lawsuits for any use including hobby or commercial use.
    This article states that Class G airspace is currently "unregulated" and that the FAA currently has no authority in this space.
    They certainly don't seem to act as if that is the case.
  • Interesting article!  The sentence that says they have no authority under 700 feet is extremely interesting to me.  If this is the case then why can't we start self regulating rules right now and begin small business use of drones?
