Ground station and config utility
When I try to run the config utility it comes up with "the application failed to inialize properly(0xc0000135)"Also the ground station wont run as this comes up withThe VI is not executable. the full development version of LabView is required to fix errorsI have downloaded and installed the two items Chris mentioned in the manualAny ideas?Paul
  • The map centres on the home position that was set when you switched on (assuming the link was in position) and using the zoom works for me in the UK.
    Peter
  • Thanks its working, I cant zoom into the map to get the uk, what format do I use for Lat-Long?
  • Do I get it from microsoft website?
  • Thanks I ll give it a go
  • You missed the Microsoft .Net Framework 2.0. Install it.
