HOW ACCURATE ARE YOUR MAPS AND MODELS?
3689638061?profile=original
Making maps with the help of small UAVs seems to be easy enough. However, when geometric accuracy is critical, how do you determine and state the estimated accuracy of your mapping product? One way is to establish a test bed with a redundancy of accurately surveyed check points which are used as independent bench marks against which the map can be compared. In this picture we show a comparison between high accuracy GPS derived check point coordinates and corresponding coordinates as derived from our 3D model. Note that for illustration purposes the horizontal errors were scaled by a factor of 1000.
The 3D model was created from 261 aerial images (13mm GSD) captured by a Sony a6000 camera with 16mm fixed lens. The camera was carried by a Pixhawk equipped modified Steadidrone quadcopter. The flying time was 10 minutes and, using our V-Map system (http://www.microaerialprojects.com/v-map/ ), we could accurately survey the 12 ground control points in about 15 minutes.
Using 105 check points in our error analysis we can now confidently claim that when we map similar terrain with this particular method we can realistically expect to achieve the following accuracy:
Horizontal approximate circular error at 95% confidence 0.028m
Vertical Accuracy at 95% confidence: 0.039m
Not bad, especially when considering that the 4.75ha map can be delivered the very next day after image acquisition.
  • Good job! We are always looking for data like this to prove to our clients how accurate UAV modeling really is. This is great as its done by someone "out of house!"Given that RTK GPS is at best 3cm accuracy in terms of heighting, the results are very close. I think a more definitive comparison would be using a theodolite to measure the control for such a small base line. Our test areas with using theodolite placed control are excellent. Obviously you will get zero discrepency at the actual control point as it is used in the transformation of the model but in those areas between tn the control and the areas extrapolated outside of the control will give you errors. As I always say. the only errors you can get in photogrammetry are control point accuracy, miss identification of control points and insufficient over/side lap. Otherwise it is super accurate. We once gave 2mm interval contours for a concrete slab in a frozen produce warehouse produced from a camera mounted onto a trolley 8m high, pushed on a predetermined "flight path". The client didn't believe us that our results were accurate enough. To prove it, we marked the low spots on our map and translated and marked them on the slab. Then we threw a buck of water over the slab and it settled right in our marks.
  • Interesting, but the problem I see is that the testing field is very flat. Try to do the same in hilly terrain. Also the area is quite small. Horizontal accuracy at the level of 2xGSD and 3xGSD in vertical plane is pretty standard. The GCPs/Check p. are at same accuracy level of 2-3cm if measured by RTK. What are the maximal errors on the Check points?
  • What about camera mount? Stabilized 2D/3D? Pitch, roll, yaw angles of photos?
    Wiat software used for ortophoto production?
  • Depending on how you surveyed the GCPs, you're within the error of the test data. RTK GPS would have precisions on that level. Are you running dual-frequency RTK on the UAS, using targets, or simple L1 code positioning on the UAS?
