A major concern with sUAS is what does the FAA consider "Commercial Use".
Here is a comment from a law firm:
" The FAA has consistently defined commercial operation in terms of whether the operator receives direct or indirect payment for the operation. It is not necessary that the operation be conducted for profit or even that there be any intent or ability to make a profit. The compensation is not just limited to monetary payments but includes anything of value. This broad definition of compensation has been affirmed and adopted by both the NTSB and the federal courts. Administrator v. Roundtree, 2 NTSB 1712 (1975); Administrator v. Mims, NTSB Order No. EA-3284, review denied 988 F.2d 1380; Consolidated Flower Shipments, Inc., Bay Area, 16 C.A.B. 804 (1953), aff'd. 213 F.2d 814 (2nd Cir. 1954)."
This definition applies to sUAS.
It is my guess that the FAA will handle this stuf the way the FCC does. No complaint = no problem.
However, all you need is a single enemy and ...... BTDT.
So two Jr. pilots can sit there, while the Sr. pilot takes a dump... and quibble all the way to the ocean floor...
But we discuss what may happen if a 2lb bird falls out of the sky... and how the faa will prevent that...
It's called freedom. (Salute)
It is much easier to prove "commercial use" under the FAA definition than to prove carelessness or reckless.
Think of an average car accident. Who is at fault or liable usually ends up in a court battle. Take the same accident but add to that a lack of drivers license/registration, not wearing seatbelts, not wearing glasses, out of inspection, bald tires and/or DUI. You now have a cut and dried "guilty" of more than just the liabilty for the accident. DUI in a fatal accident (even if it technically isn't your fault) will get you a negligent homicide charge in most states.
So, how much do you have to lose if something goes wrong? Is what it comes down to.
The real purpose behind these broad rules is to have something to plug ALL the loopholes in the event of an incident.
And Duane is right, if your friends can pay their share of a flight. They just can't pay your share too.
Technically, companies can not do so outdoors (unless it is an educational 501c3 NPO).
Indoor flight is not under FAA control though.
The FAA is not running around tracking down people (just like the FCC).
Rest assured that if anything bad happens the NTSB and the FAA will nail you to a cross.
Also, if you have any enemies (or neighbors) that want to make a case against you, you will be giving them lots of ammunition.
This is such a broad definition of what is commercial my mind is blown.
"So a model company that is testing its newest design, is a commercial use???"
I am not sure on this. Do manufacturers of other recreational aircraft get their prototypes classified as?
I am fairly certain (my memory is hazy) but I think the military protptypes I worked on were considered commercial aircraft. It was not until the Govt gave us a contract that the production aircraft were public aircraft.
