Following the death of the Ugly Pink Quad's 4th thruster, Entirely accidentally, I am going for a tri-rotor design, on
a 1/4" plexiglas base, with 3 Futaba S3003 servos for vectoring thrust.
The Nano that was originally being used for the Ugly Pink Quad, and now the Tri, well...it died, so in comes the DFRobot RoMeo.
My initial idea is going to be to use the thrusts of the three ducted fan units to stabilize horizontally and control altitude, while using vectoring to produce the X-Y translations and yaw motions as needed.
Given the wide, flat body and the ability to vector thrust, I might be able to use the plexiglas as a lift-generating device to aid battery life when not merely hovering.
Given that lift, and position can be somewhat decoupled, it may end up a very stable platform for cameras and such, even in breezy conditions.
I hope to have the IMU stream stabilizing the platform by mid-week.
First test with the AFSoftwareSerial for COMMs with the ArduIMU seem promising.
Alex - Thanks! That's a monster, over and above what I was thinking - It's a work of art.
Ryan - Found a half dozen of these years ago, and planning to try using it with an OpenServo board as a light/fast linear positioner, but in the meantime, it's just feeding an analog input for thrust control during testing. I find the linear pot gives a more sensitive feel than the rotational one that's controlling thrust angle.
Cheers
As a nod to the blade-pitch-wise comments, I have a question:
Have any of you tried making quadrotors with variable-pitch props?
I think it would be fascinating to take four RC helicopter tailrotor assemblies, run them at a constant RPM, and change thrust by varying pitch.
One strong motor, centrally-mounted, could power the four props by belt drive, and four micro servos, together, would be lighter than the usual set of 4 motors with ESCs.
What is more responsive? Variable pitch with a 0.06sec tail servo, or variable speed on a constant pitch?
See..........Incurable MultiProjectitis........ :-(
Since I am early in the development phase, I want the polar moment to be high. It'll make the whole thing less responsive and twitchy. As it gets nicely tuned, I can then concentrate the mass toward the middle, making it more agile.
Cool toy.
The closer everything is to the center of mass the easier it is to turn. You are trying to pivot a lot of mass with the ducted fans alone. I would move the boards, the ESC's and the battery to the center.
You are pushing a huge amount of air with that large piece of plastic.
That information is what I hope to get from future testing.
What I know to begin with however is:
1) If you picture the pitch of the prop as tracing a spiral through the air, if a point on that spiral is moving at the same linear speed as the airframe's airspeed, the fan thrust becomes zero. So for a given RPM there's a max airspeed where thrust drops to zero. (Ignoring airframe drag for now)
2) As airspeed decreases, the angle of attack of the blades increases, and "lift" (aka thrust) also takes a hit.
Therefore any bladed propulsion system will have a curve to it, a performance range that's acceptable, and a sweet spot to try for.
1
2
of 2 Next
