We're delighted to announce the new APM 2.5+, which is the same APM 2.5 board you know and love but surrounded by lots of new goodness! Now, for a new lower price of $179, it comes with all this, right out of the box:
The new APM 2.5 enclosure, available in both top pin (above) and side pin (right) styles. It's designed to keep your electronics safe while looking great at the same time! The enclosure is made of black translucent ABS plastic so you can see the board's LEDs. It protects your electronics while allowing access to all pins and connectors. The inside of the enclosure is lined with ESD safe open cell foam to ensure the barometric pressure sensor is surrounded by static air and prevent unwanted readings due to airflow over the sensor. And the screws that secure the enclosure have been moved to the top for ease of use. It's also available as a stand-alone product for $4.99. (customers who already have an APM 2.5 are eligible for a coupon code to get a free enclosure with their next order. Email sales@3drobotics.com if you don't already have one)
The new APM Power Module, available with either XT60 (shown) or Deans connectors. It's a simple way of providing your APM 2.5 with clean power from a LiPo battery as well as monitoring current consumption and battery voltage measurements, all through a 6-pos cable that plugs in neatly. The board is also shrink-wrapped to protect it (the bare board is shown here so you can see the innards). Been wondering what that "mystery connector" was on APM 2.5? Now you know! This will ensure that you have no brown-outs due to insufficient BEC power from your ESCs, and makes current and voltage monitoring easy! It's also available as a stand-alone product for $24.99
Our new Version 2 of the Mediatek GPS module. This takes all the learning we've had with the Mediatek over the past two years and wraps it up in one vastly improved product. New big ground plane antenna to improve reception! On-board battery for fast lock! New firmware for better performance and datalogging! Also available as a stand-alone product for $37.95.
Oh, and did I mention that we also lowered the price of APM 2.5 by $20 at the same time?? This is all thanks to our new production facilities in Tijuana, which allow us to make an increased volume of products at higher quality and lower prices. We're even adding a new Manncorp four-head pick-and-place machine there to handle even higher volume!
Joel: Your receiver will be powered by your ESC as usual. This module is just to power the autopilot and associated electronics (3DR radio, GPS, etc)
Question regarding the power module: I understand I need to disconnect JP1, but will the receiver still be powered from this module?
I am wondering what the pick foam is for? I am thinking it is to protect the Baro from shifts in the alt. but I want to make sure. If anyone can answer or verify I would appreciate it.
I hope mine will also. Order# 35307.
Great, I will order another after the backlog clears :)
F11; $179 for the whole set is now the standard price. It helps run to run our own production!
Chris, is this lower price going to stick or is it just a black friday sale? I was thinking to pick up another one.
Jerry: My apologies - I misread the date of your order. I can have the team send you a free case. Do you need side pins or top pins? Please PM me your address, too.
Order date: 11/25/2012
Order#: 34938
If you look above, your article dated 11/23 stated:
"It's also available as a stand-alone product for $4.99. (customers who already have an APM 2.5 are eligible for a coupon code to get a free enclosure with their next order. Email sales@3drobotics.com if you don't already have one)"
So I'm not sure why you think my order was placed before this. If anyone has a used case they would like to sell me, I would sure appreciate not begging anymore! I would be happy to pay more than it cost!
Thanks!
1
2
3
4
5
of 11 Next
