Long Endurance Flying Technology Prototype
Please see the video below for a description of my fuel cell controller (so far) for a remote controlled plane. A fuel cell provides much greater energy density than a battery, so for long endurance it is far superior (hours). Hopefully, with a bit of refinement I'll have the system flying in my SkyWalker X8 in the spring.
 Feel free to comment, I look forward to sparking some interest!
Simon
  • I know you can make it DIY style but assumed you would need quantities which would make the DIY route slow/not-really-worth-it.
    What is the weight of the cell and what, at your cruise speed, would the consumption be? I'm trying to understand how this would supplement the main battery (in a hybrid solution) compared to just piling more LiPos into the mix.
    It is a pretty interesting idea to add to the RC world though. I'm thinking about the guys in South Africa and Namibia doing the anti-poaching flights. They would benefit from ideas like this - long slow flights.
  • Hi all, thanks for the comments,
    Hydrogen can be generated easily using an electrolyser (one of these fuel cells in reverse). I'm using one of these. There are of course other methods. Gaseous H2 is much the way to go for this application, liquid would prove to be too heavy due to all the safety ancillaries you would need to vent the boiling off H2, which would then be dangerous near so many electronic circuits (in my opinion).
    The rated max output is 120W, which is 12v at 10A. Sustained is 100W (so you're not destroying the cell) so probably around the 14v 7A mark. Should be just enough to cruise from test flights I've done monitoring power, cutting it fine though. At worst it will be a range extender in this first proof of concept prototype, 95% fuel cell and 5% battery, to pluck some numbers out of the air.
    The bench test is more for the academic side, o it isnt the final motor, ESC & prop choice I'll be using. Also, in the hybrid the fuelcell will be 12v or 14v down regulated to match a 3 or 4 cell LiPo. A touch inefficient, but more simple on the RC side which is one of the main aims.
    There is a bit more info on another video on my personal DIYDRONES page.
    Simon
  • You can make hydrogen using electrolysis, some people think it is too dangerous. I have never done it but it looks like if you are aware of the properties of the gasses and how to properly handle them then it is relatively simple. If the cell uses liquid hydrogen that makes it more complicated though. Don't know if you could do that.
    I would be sure too that if you can buy a fuel cell you can get fuel at the same shop.
  • Very interesting. How would you carry the hydrogen weight / capacity or container?) and what is the consumption like?
    Can man-in-the-street get hydrogen?
