Low cost version of APM2.5
Hi everybody, I have just finished this low cost version of APM2.5 because it's difficult to buy a original board in my country, so I decided to build my own hardware with two layers PCB :)
I have solved some bugs in hw such as:
3689585651?profile=original
I also added a filter for AVCC for better adc result:
3689585737?profile=original
Modified PPM Encoder which is more simple in connection than original:
3689585872?profile=original
with one 3.3V SPI extension to connect with other 3.3V SPI device
3689585904?profile=original
The hardware worked well. data from sensor:
3689585830?profile=original
Next test, set up it to frame with full supports for a quadcopter and...fly
This version costs about $53, nice price, hah ^^
Some pictures (Dimension: 56mm x 56mm)
IMG_0389_zpsfd387535.jpg?width=700
IMG_0404_zps5709e462.jpg?width=700
IMG_0401_zps5ac7d64e.jpg?width=700
IMG_0413_zps44d4fefb.jpg?width=700
Bottom, I'd like to change original name for my new board? Is it OK?
IMG_0366_zps4ff508df.jpg?width=750
I'm considering to open this hardware after I finished all test for this board. Someone can tell me any legacy problem when I share my Altium design to open source community?
Note: xtPilot is a modified hardware based on the APM2.5 open-hardware project.
  • did you use a reflow for the surface mount elements?
  • impressive indeed, could you show some of the process and equipment used?
  • You soldered that by hand?  Respect.
    You could definitely shrink it down more by getting rid of some of the commonly unused bits.
  • It's a work of art, Xuan! Nice to see a constructive derivative of APM.
  • @Graham: I did it just for hobbby :3 no plan yet!
  • MR60
    impressive! how was it built ? looks like it was mass produced and not hand made.
  • @Luis: $53 for all. Yep, I solder all components by hand @@
    @Hein: I'm sorry, I forgot to check with kk2 :D
    @Thomas: I've recalculated, It just costs me $47.731, but AIO doesn't have enough feature like apm2.5, Sir. If I choose another components to replace the original components and reduce some of them but still keep the hardware works well, cost can be reduced to approx. 45$ @@ lol..
  • anyway you could miniaturize this by completely removing PWM RC input leaving only ppm with all surface mount mini connectors (HKmini like)?  and making  connectors+LEDs and  baro on opposite board faces, so the board can be mounted with the baro facing down and connectors/LEDs up like on a pixhawk?
    otherwise an interesting form factor (with room for improvement)!
  • 100KM
    Exciting!! Does it have the same drill holes spacing as a kk2? Well done!!
  • is 53 all or just the PCB?
    did you do all the soldering by hand? thats quite the skill the photos look pretty good.
