There it is. The cheapest $47 bare board uBlox-5 available + $14 shipping.
As flimsy as it is, the hope is it'll be obsolete by the time it falls apart. The helical antenna only has 3 solder points, so the $90 brand name version probably wouldn't last longer. Knowing the wars about diydrones product offerings, we're not going to tell you where to buy the $47 special.
Voltage regulator attached.
Now your 1st look at the helical antenna. The rubber enclosure slides right off, revealing:
Is it a revolution in lighter weight, omnidirectional reception or another gimmick like fiber optic servo cables?
Unfortunately a killer commute & difficulties with the Air Force have this myth inching along. Have some commute footage instead.
2 quick questions .......
1) is this a genuine product or a knock-off/copy of the genuine (Ublox been the genuine - with a Sarantel (?) antenna)?
2) whats the diameter of the white dielectric material onto which the 4 copper helix elements are bonded (I can then work the helix dimensions out and run a bunch of paper-calc's)?
Thanx
Patrick
