It's teardown day at DIY Drones ;-) Sparkfun has a great one on the Neato Robotics robotics vacuum cleaner, which has a cool Lidar unit. From the post:
"Inside you can see the laser and the CMOS imager that the Lidar uses to detect distance to objects. The white paper on this device insists that it can be built for less than $30, but right now the laser can only be bought if it's inside the robot. Still $400 dollars is a low price for a device that does 1-degree accuracy planar scanning at 10Hz. There are four wires running to the laser assembly. Upon closer inspection, we see that these wires are soldered to pads on the board labeled "TX", "RX", "GND", and "VCC". So it's not exactly tough to figure out what communication protocol the device uses."
So far the Sparkfun team have gotten some basic info (see below) out of the device, but it's not fully hacked yet. But given that Robotox has offered a $800 prize for doing that, it's just a matter of time!
it looks like the processor is a TMS320F28023PT
Texas Instruments Piccolino DSP
http://focus.ti.com/lit/ds/symlink/tms320f28027.pdf
PARTID Register Field Descriptions
7:0 PARTNO These 8 bits specify the feature set of the device as follows:
0x00CF TMS320F28027PT
0x00CE TMS320F28027DA
0x00C7 TMS320F28026PT
0x00C6 TMS320F28026DA
0x00CD TMS320F28023PT
0x00CC TMS320F28023DA
0x00C5 TMS320F28022PT
0x00C4 TMS320F28022DA
0x00CB TMS320F28021PT
0x00CA TMS320F28021DA
0x00C3 TMS320F28020PT
0x00C2 TMS320F28020DA
0x00C1 TMS320F280200PT
0x00C0 TMS320F280200DA
