The Easy Star Electronics Chassis is being added to the DIY Drones store today. This accessory allows you to mount your APM/Oilpan, GPS Module (Mediatek or uBlox), Differential Pressure Breakout, Receiver, and pan/tilt camera mount on your Easy Star. The chassis provides access to the CLI switch, USB connector, and the Reset button as well as providing a clear view of the ‘ABC’ LED’s on the Oilpan at all times. It is also compatible with two GPS modules; the uBlox module can be mounted to the vertical plate near the back and the Mediatek gps module fits perfectly on the shelf above that (or you could use some double sided tape and stick any module anywhere). Most receivers should fit on the top base and can easily route wires to the APM beneath. The APM is mounted on the bottom and once it is mounted there is no reason to take it out as everything is accessible, but if the need arises, the bottom plate is designed to pop out more easily than the rest of the chassis so there is no need to take it all apart.
The chassis will be sold in two configurations, one with the pan/tilt camera mount (which you might recognize from Jeff’s post earlier in the week) and one without. Hope you like it and happy flying.
http://h9z6z.kmn9z.servertrust.com/Easy_Star_Electronics_Chassis_No_Pan_Tilt_p/es-chassis.htm
sent you a message
The two arm pieces that connect the back piece to the base piece is a bit too thick and the slots on the back piece is a bit too small. Tolerance was a bit off and I can't join them
I'm glad it was meant to take a crash O_O
It's fiber. Black FR4.
http://www.americanepoxy.com/g10fr4sheets.html
What material is this chassis made of?
That's great :-))
One of the platform I am using is a Twinstar II. Are there any electronic chassis for this bird ?
Does anyone know if this is compatible with the Hawk Sky?
