The very low internal resistance of the Batteries (typically 8 – 10 milliohms) give huge benefits such as:
- Far longer battery lifetimes with upwards of 1000+ cycles expected for a battery pack.
- Lower heat build-up during the discharge cycle.
- Faster cell recovery.
- Lower voltage drop under loads, which equates directly to a much higher RPM per volt from your electric motor.
- More available power for the battery pack.
- Ability to charge at higher charge rates (It is important to allow the battery to cool below 25c before charging commences).
- Suitable for all applications and especially so for use in high current applications.
If you wanna try them for your R/C project, you can find them .... Lightspeed Batteries
Dean that correct! Thanks for the info!!
Altairnano when designed this tech noticed that the voltage of the batteries was lower, but later they got it fix and the current versions are = in voltage to the reg lipos.
This Nano-particle oxide fillers can be SiO2 , LiO2 or Al02 and their job or effect on the cells is to increase conductivity.
actually I was looking on the TP specs sheet those are the TP G4 V2 20C are you talking about?
The TP G4 V2 20C - 40C will be lighter being in the same category for the "C" rate, usually a battery of 20C will be lghter than a 40C and so on. Less C less weight.
If you compare this same battery category:
TP G4 V2 20C with the TP G4 PRO Power 30C - 60C its heavier being 808g
and the TP G4 Pro Power 45C - 90C 822g
Thats why the Titanate 5000mAh 60C - 110C 829g will be heavier ;)
I think that a TP or other brand lipo under the same "C" rate will be at the same weight or only a few grams of difference.
I think this post has gone from a informative purpose to a battery challenge and thats not my intention. I think that why we just keep the post informative and bring other tech similar to the Li-Ti to discussion and learn from each other post.
I found really good stuff of what happens to our lipos while charging and discharging, thats a good answer to why this lipos life is short. I will be pleased if the informative contributions continue for the knowledge of our members! :)
No. Lithium Phosphorus was the perfection of LiPo. Surprising how little we know about battery physics. Only recently has anyone tried documenting what happens to the electrodes.
Well comparing weight
Turnigy nano-tech 2200mah 3S 35~70C 3 cell 11.1v Lipo Pack......199g with wire plug and wraping
Lightspeed Lithium Titanate 2200mAh 40~70C 3 cell 11.1v Lipo Pack......195g with wire plug and wraping
its almost the same, LiTi lighter by 4 g but that insignificant.
Hi Ken liked your info, and thank for posting it!!
what i was trying to say is that the issue with the normal anodes already used and also the carbon anode is that  when we charge and discharge this kind of batteries  the anode suffers an effect called Lithiation, slowly degrading the anode because of the flow of ions through it. by time a degraded anode start causing all the problems we already know about. I believe that this is the reason why by safety we should not charge a regular lithium pack over 1C. a higher rate will cause a faster degrade on the electrodes and death of the battery.Â
Here is the video... Look at the ions flowing like juice on the wire making it to swell and contort
1
2
3
of 3 Next
