PARACHUTE anyone ?
3689396321?profile=originalMaybe someone has encountered a small scale parachute ?
I'd like to add a safety parachute to the Arducopter !! help me decide....
As part of the project is to use an expensive DSLR on the copter,
My GF said i must have some kind of emergency parachute... after joking at it, i thought deeper -
I'd rather feel much safer having a parachute as backup to all electronics (even though i plan on 6 or 8 motors)
Just imagine an emergency button that will immediately turn off all motors and shoot a parachute.
questions:
as parachute takes some time to open (=some free fall height), the benefits are sure and obvious for a 100m fall.
but if i'm around 5m above ground, (which can still be nasty to the DSLR) - would i have enough "falling time" to open the parachute and having enough braking force ?
think i better make one by myself ? is it rather simple as cutting and connecting wires to a cloth,
or it is more complex design that i could hardly achieve and i better get a ready one ?
i came across this as the only parachute i could find:
http://cgi.ebay.com/NEW-40-SPEED-RUNNING-POWER-CHUTE-training-parachute-/220760637799?pt=LH_DefaultDomain_0&hash=item33665c0167
It looks sturdy and well balanced & stuff... it's totally affordable !
they say the 40" version has 7KG resistance. i'm safe on this side, i dont want a much bigger one.
how about the opening technique ?
i could stuff it in a small plastic tube attached to the top of the dome, using a small solenoid or servo to kick it out...
how do i ensure it opens reliably ? i guess it depends on the folding inside the storage tube...
  • I've been thinking about how to deploy the chute deployment without pyrotechnics or stored air pressure..
    An umbrella comes to mind, and ....
    ..I'm wondering if small graphite rods could be fastened in the same manner, if they could be somehow curled up when packing the chute. And they would force or at least encourage the canopy to open quickly.
    Perhaps a light weight plastic with lots of 'memory' could be used. Music wire might work.
    Next time I'm at the hobby shop I will see if there is anything that I can find to do a simple test.
    A spring, as Gary mentioned, for ejecting the parachute may be the simplest way to get clear of the copter.
    The toys (guns) that shoot those darts with suction cups can get some range....they also have a trigger mechanism that may also be useful.
  • i can understand that,
    just tested a 80A 100mm EDF yesterday !
  • I see,
    breaking is an option. i hope it won't affect with very high torque resulting in yaw or flip over... (remember one motor is probably gonna be dead)
    Yesterday i tested what happens when you disconnect the ESC while motor is running:
    it was a generic ESC (not arducopter), when i disconnected the signal it started to jump between 0 throttle and the throttle it was left on, randomly.
    though maybe connecting the signal line directly to ground might tell the ESC to stop also - have to check.
    so for active breaking i have to put relays on the ESC's signal lines that will take the signal away from the APM, and connect all together to a servo tester outputting "0" throttle.
    that's not too hard.
  • The latter, basically it just energizes the coil or coils statically, with no commutation, so rotation is inhibited.  It will consume some current while doing so, but you can adjust it with many ESC's that allow programming.  Obviously this only happens when throttle is considered 0, since normal operation requires appropriate commutation.  (Which the ESC provides for brushless motors, which I'm assuming here).
  • Chutes used in High Power rocketry might be an option, I'd also look at a mesh parachute (mesh on the bottom instead of lines), just to avoid tangling issues with all the rotors.  As for deployment speed, without a forceful deployment you will have drop before it opens, you could use a power deployment with a cardboard tube (which then helps clear props too) ala HP Rocketry (usually a small BP charge).  But I wouldn't do that without looking at the potential regulartory issues.  A spring/piston might be a better choice....
    Perhaps you can also reduce reaction time with a deadman switch stick that you just drop if things go bad.  Probably faster than fumbling for a toggle anyway.  You'd need to enable aggressive and active breaking on your ESC's to stop the props in time, not sure that's worth it.
  • mmm, this might be a bit too far...
    the camera mount and landing gear around it will be made of thick aluminum tubes, i think it's a good protection, even if they bent a little, there still will be room before hitting the camera. and yes i can add foam....
    anyways, i'm not aiming to save only the copter,
    why not saving BOTH at once with a single parachute...?
    after all the copter costs like 1/2 the DSLR....
    what i've got to keep is an option to disable it totally - even if it's 100% manual.
    if i'm flying near the sea or a lake, i'd prefer it smashed on the ground rather than drown in the water....
  • While you want to save the copter, your REAL concern is the DLSR. So, considering the issues with whole copter recovery, why don't you look at the other end? Build an impact resistant (plastic and styrofoam) shell around your DSLR. Mount that into your gimbal cradle. If something goes wrong, eject the whole module. Attach the parachute to the rear or whatever puts the most foam between the camera and its impact. A spring ejection would clear the camera from the chopper, provide velocity to inflate a parachute, and keep you clear of the rotors in one fell swoop. If the chopper is in flight, this may destabilize it, but the ejecting capsule could clear a second chute out of the frame. Flight gains could be adjusted to correct flight, too, if need be, to adapt to the change in center of gravity and weight. It'd also be actually testable without risking copter or DSLR.
  • Guys, i stick to the parachute, i know it's not a magical solution,
    but as far it seems the best.
    I have no idea how the quad might fall, but something makes me believe that the heavy DSLR at the bottom of the quad will keep it falling horizontally aligned (like the ground position), so hopefully the parachute will shoot vertical to sky....
  • I have had a lot of thought regarding "Fail Safe" solutions.
    Recently I've taken this route from NASA.  The Daily Planet had a piece about these and I was amazed at how simple but effective it was.
    They are called "deployable energy absorbers".
    http://www.nasa.gov/topics/aeronautics/features/helo-droptest.html.
    On the TV show they were able to bring the G down by more than half.
    Cheers!
  • The chute needs to get out into the relative wind in a hurry and deploy rapidly. This might mean a deployment system such as a ballistic charge but probably more likely spring loaded. I was a skydiver for almost thirteen years and my pilot chutes were all spring loaded. Pulling the ripcord separated the two halves of the container on my back which allowed the pilot chute to spring out and catch the wind.
    If you were to deploy too soon (or by accident) on your copter rig, there might not be any relative wind to act upon the chute, if the copter wasn't falling, and the chute could possibly tangle around one of more of the props. If you were to deploy while the copter were falling and tumbling, this too could end in disaster. A parachute is not a 100% fail safe method. It would be interesting to have inflated air bags much like the Mars landers but of course not real practical in this hobby.
    If you wish to look futher into parachutes, here are some links that will help you design, buy materials to make your own or purchase ready made products that might work.
    http://www.pcprg.com/sptp.htm
    http://www.madehow.com/Volume-5/Parachute.html?Comments%5Bdo%5D=mod...
    http://www.aeraustral.com.au/parachute.php
    http://www.strongparachutes.com/pages/pc_intro.php
    http://www.paragear.com/templates/base_template.asp?group=27#P2550
    http://www.paragear.com/templates/parachutes.asp?group=193&level=1
    http://hienergy.tripod.com/Hang%20gliding/PC%20misconceptions.htm
    http://www.aerosekur.com/parachutes/parachutes_index.html
    http://www.olywa.net/yosemiteflash/parequip.htm
    http://www.thirtythousandfeet.com/parachut.htm
    http://www.apogeerockets.com/parachutes.asp
    Best of luck
    Gary
    Toy Parachute - Science Projects with Toy Parachutes
