This video show that the controller working for the first time. !!!!!Awesome!!!!!!
I could barely keep a wheelie up and going before I started using my controller.
Tuning the code a little more before the ride. >>>>>>>>>>>>>>>>>>>>>>>>
Ever since I was a kid I wanted to ride wheelies. So I built a Arduino Wheelie Controller and started enjoying longer, safer wheelie'ing. I use an Arduino Duemilanove ATMEGA 328 to control a LARGE digital servo powered with a homemade servo power curcuit, coupled to a hydraulic hand brake. The handbrake is connected to a steel braded brake line that runs down and connects in place of the rear hydraulic brake reservoir. The controller uses a triple axis accelerometer and a single axis gyro to calculate when and how much brake to apply. This controller can be used on 4wheelers and motorcycle with rear disc brakes.
<<<<<<<<<< Controller
1.)Arduino Duellinove
2.) Triple axis accel & single axis gyro "Black Box"
3.) Power supply for LARGE servo
4.) LARGE DIGITAL High speed & Torque servo w/ metal gears
I connected my servo to a handbrake like this one and mounted it under the rear fender. >>>>>>>
I used this adapter to connect my handbrake to the rear brake master cyclinder.
No way would I try controlling the throttle on this quad way to dangerous. U need a 3 axis accel.
You could use a dual axis accel but I don't recommend it. I used 2 axis to determine pitch of the quad. I use the 3rd axis to tell my program that the quad or motorcycle is standing up and is not fallen over. When i was testing it on the bench i knocked over my test stand and the brake servo went crazy. This answered the question of what would ha[[en if you fell over on a motorcycle.
Nice Job! I understand what you said about using it as a training aid, but I was wondering if you have tried controlling the throttle instead of the brake? Another idea (not saying its a good idea) would be to control the vehicle pitch with the throttle while in the air during a jump.
Do you need a 3 axis accel or is that just what was there?
original one !
what the controller is actually doing it to limit the throttle at the points it gets to 45 degrees angle ?
so your gas now is some kind of pot ? :)
@ OLE It's no joke it really works. :)
@ john is it a rock crawler type jeep? yes it will help to keep the front tires down when climbing. Whats funny is the code for this project is very simple. Although I have lost it due to a computer crash. Now I know it my head becuase it took about 3 months to get it figured out.
1
2
3
of 3 Next
