Spektrum DX8 and AR8000 Failsafe setup
I've been struggling to understand how to get the APM failsafe working properly and have yet to find some clear instructions that a noob like I can follow. It suddenly dawned on me how to get it all setup.
Here is my normal zero throttle output:
3689450214?profile=original
Here it is when the radio is off:
3689450232?profile=original
The AR8000 can be taught what to do if it looses contact with the mothership. The default is to leave or move the throttle to zero. As you can see, zero is normal and not enough to invoke the APM failsafe. (see here for more info on the APM Failsafe: http://code.google.com/p/arducopter/wiki/AC2_Failsafe)
What you need to do is tell the AR8000 to go below zero when the radio is lost and here's how you do it:
  1. Turn on the radio and go into servo setup.
  2. Find the throttle travel setup (on the DX8 it's the first screen)
  3. Scroll down to negative travel (Left hand 100%). Change that to as high as it'll go. 140% in my case.
  4. Confirm in Mission Planner that throttle input is now around 920uS
  5. Turn off radio and receiver.
  6. Insert Bind plug into RX and turn on.
  7. Remove bind plug from rx. Light should continue blinking.
  8. Ensure throttle stick is down.
  9. Turn on radio while holding down bind button. Radio should rebind.
  10. Turn everything off.
  11. Turn radio back on and change the throttle throw back to 100%
  12. Turn on quad and connection with MP
  13. Confirm that minimum throttle is back to around 1100.
  14. Turn off radio and throttle should now drop to around 920uS (or whatever it was beforehand)
  15. If not, start again.
  16. Now go to parameters in MP
  17. Find THR_FAILSAFE and set it to 1.
  18. Find THR_FS_ACTION and set it to 2 (1 = continue on Auto mission, 2 is RTL)
  19. Click on the write params.
  20. Click on Refresh to ensure it wrote it.
What you have done is told the receiver that when you loose contact, this is the new throttle position. It is of course, way lower than normal range. The low value is enough to trigger the APM failsafe which will RTL and land.
This all works in theory for me and MP seems to agree, I'll be out testing it tomorrow but just wanted to get it all down on paper so to speak.
  • Hi Crispin,
    You said, "An idea might be to only enter failsafe if armed AND there is movement in the sensors (i.e. you;re in flight). Will add a note to devs."
    This sounds like an excellent idea ....  Did you send anything to anyone about this?
  • I thought of this last thursday but didn't implement it that night as I don't usually fly out of range. On friday I flew behind some telecommunication tower at close range and the inteference caused a signal loss when it was out of LOS, quad fell like a rock. Lesson to self: TRUST THE INSTICT
  • 100KM
    Ok, over the weekend I let it circle (for I guess 20 seconds..) and RTL kicked in. What an awesome thing this :)
  • 100KM
    Brilliant, makes so much sense now that I understand.. Thanks Crispin. I'm flyinf Arduplane, I don't seem to have a THR_FS_ACTION. Setting THR_FAILSAFE to 1 or 2, just causes it to go into CIRCLE mode, how can I get it to RTL?
  • A worthy note. It did happen to me. After flying I had the quad in front of me on the ground and still armed (stupid, I know) and turned off the TX. It tried to shot up but due to low batteries, was rather sluggish and I managed to get my face out the way. Could have been interesting.
  • Thanks Mike. I'll get it updated.
  • should it be about the same for futaba 8fg
  • I should have added something else to the blog.
    The above will should work for most receivers which have some sort of fail safe mode. You need to find where you set the travel limits for your throttle (In the Spekrum it is Settings > Servo Settings > Throttle)
    Your TX and RX then see this as the zero throttle. You need to then see how to tell your RX "in time of panic, go to zero throttle" As this new zero throttle is enough to trigger the APM fail safe, it'll do it just fine.
    Once you've done that, you need to change your throttle limits back to normal.
    You do not want your normal throttle zero to be able to trigger the APM fail safe!
  • Would this work for the Turnigy 9x?  I upgraded to the ER9x firmware.  It's reading a 972 pulse on THR/CH3 with the stick down at zero, the motor starts at 1050, but when I turn off the radio the last pulse settings remain.
    I read that you can program the ER9x to send alternating signals every few microseconds that APM2 can detect, but the APM2 code needs to be modified to read it.
    Any way to set the 9x for failsafe with APM2?
    Nice one! Now added to the manual here.
