I've been struggling to understand how to get the APM failsafe working properly and have yet to find some clear instructions that a noob like I can follow. It suddenly dawned on me how to get it all setup.
Here is my normal zero throttle output:
Here it is when the radio is off:
The AR8000 can be taught what to do if it looses contact with the mothership. The default is to leave or move the throttle to zero. As you can see, zero is normal and not enough to invoke the APM failsafe. (see here for more info on the APM Failsafe: http://code.google.com/p/arducopter/wiki/AC2_Failsafe)
What you need to do is tell the AR8000 to go below zero when the radio is lost and here's how you do it:
- Turn on the radio and go into servo setup.
- Find the throttle travel setup (on the DX8 it's the first screen)
- Scroll down to negative travel (Left hand 100%). Change that to as high as it'll go. 140% in my case.
- Confirm in Mission Planner that throttle input is now around 920uS
- Turn off radio and receiver.
- Insert Bind plug into RX and turn on.
- Remove bind plug from rx. Light should continue blinking.
- Ensure throttle stick is down.
- Turn on radio while holding down bind button. Radio should rebind.
- Turn everything off.
- Turn radio back on and change the throttle throw back to 100%
- Turn on quad and connection with MP
- Confirm that minimum throttle is back to around 1100.
- Turn off radio and throttle should now drop to around 920uS (or whatever it was beforehand)
- If not, start again.
- Now go to parameters in MP
- Find THR_FAILSAFE and set it to 1.
- Find THR_FS_ACTION and set it to 2 (1 = continue on Auto mission, 2 is RTL)
- Click on the write params.
- Click on Refresh to ensure it wrote it.
What you have done is told the receiver that when you loose contact, this is the new throttle position. It is of course, way lower than normal range. The low value is enough to trigger the APM failsafe which will RTL and land.
This all works in theory for me and MP seems to agree, I'll be out testing it tomorrow but just wanted to get it all down on paper so to speak.
@Sergio
Yes, that is how it works. Mine is setup like that as well but I have not tested it in real life. Have you tried it?
A simple way for testing FS is to take the props off.
Throttle up and put it about 50%. Heli now thinks it's flying.
Move the quad about 20m and place it at a different height (up on a table or something).
Trigger the FS and listen to the motors. They should increase in pitch as they try to climb and then RTL.
JTK,
I don't know if it'll behave like that. I've not used the receiver for a while now since switching to Pixhawk. Give it a try and let us know how it goes.
Cheers,
just wonder if same setup will work on my futaba 9c? thanks in advance
Yep, field tested. It was between 1-2 meters.
I'll check it again later today and let you know what happens.
I just tested FS_THR_ENABLE set to 1 and it worked. Spektrum DX7s
I couldn't find:
Is this the correct parameter:
Throttle Failsafe Enable (ArduCopter:FS_THR_ENABLE)
The throttle failsafe allows you to configure a software failsafe activated by a setting on the throttle input channel
You won't see the throttle go to cruise in the APM radio calibration section as that is reading the values from the rx. The throttle will stay below normal zero which is how the APM detects the failsafe condition.
You might see it in the logs and tuning graphs though. Without checking, it will be something like Throttle-Out.
I've not actually looked for that though.
Thanks for your guidance and I have done exactly that. When I switched off my Spektrum DX8 transmitter PWM drops to 925 but Mission planner shows Stabilize mode irrespective of what mode I was in before switching off my TX. How to correct this? Thanks
Hi Rick,
I think there was already a log raised for it but it was a low priority.
Crispin
1
2
3
of 3 Next
