To Tricopter or to Quadcopter ..... That is the Question
Maybe you are one of those who googled for the difference between Quadcopter & Tricopter. For sure you found many feedback and comparisons.
Mainly the difference will be regarding power consuming, or mechanical complexity. Some prefer Quadcopters for its simplicity to build and fix, others prefer TRICopter for its ability to YAW more aggressively.
In this acticle we will discuss deep differences between Quadcopters & Tricopters, and the point here is flying & stability equations difference between quadcopter and Tricopter.
First Lets discuss Quadcopter Equation - no details here just a fast review-:
more details in broken english is here
3689669589?profile=original
There are three core equation for Stabilizing & Flying quadcopter is:
assuming M1, M2, M3, M4 are thrust for each motor.
equation #1:
Thrust(M1) + Thrust(M2) + Thrust(M3) + Thrust(M4) = Total Thrust  ... and this is determined by Thrust Stick only.
equation #2:
Thrust(M1) + Thrust(M3) = const. ... determined by Thrust stick equation #1
Thrust(M2) + Thrust(M4) = const. ... determined by Thrust
so for example when you want to roll anti clockwise, you increase M2 thrust by x and decrease M4 thrust by x. so that Equation 2 is always Valid under the same Thrust Stick position.
So for a roll a typical equation is:
M2 = Thrust + StickRoll * factor + PID (IMU ROLL)
M4 = Thrust - StickRoll * factor - PID (IMU ROLL)
so what you add to a motor is substracted from the other one on the same bar. That is because we need to keep the third equation valid:
equation #3:
Moment (M1 + M3) = Moment (M2 + M4)
This is very important because this is HOW QUAD make and correct YAW. Quadcopters -hex & octa- correct YAW using moment difference between motors on different bars.
So when we want to Roll equations are:
M1 = M1 + Stick YAW * factor + PID (IMU YAW)
M3 = M3 + Stick YAW * factor + PID (IMU YAW)
M2 = M2 -  Stick YAW * factor -  PID (IMU YAW)
M4 = M4 -  Stick YAW * factor -  PID (IMU YAW)
What you can notice here from above equations is that no equation CONTRADICTION with the other two. Ideally of course, as in real world we make some assumptions:
1- thrust is linear with motor signal sent to ESC - which is false but works :) -.
2- motor response to signal change instantly, so we read the very last IMU signal and send correction. especially if we use P only no I or D, we read the only last value, which is not true as it may has nothing to do with the last change because of inertia of propeller, quadframe ...etc. but again it works :)
Now lets go to Tricopter
3689669626?profile=original
The following equations are used:
equation #1:
Thrust(M1) + Thrust(M2) + Thrust(M3) = Total Thrust ... and this is determined by Thrust Stick only. same as quadcopter.
equation #2:
Thrust(M1) + Thrust (M2) = const for ROLL
but wait. Motor M1 & M2 acts as one virtual motor with M3 for pitch stabilization.
so Thrust (M1 + M2) = virtical Thrust (M3) = Thrust (M3 ) * Sin (ceta)
This is OK as for Roll we add x for M2 & subtract same x from M1 and it will not affect the pitch stabilization -at least in theory-.
Now lets go to the equation of YAW:
equation #3:
Moment (M1) + Moment(M2) = Thrust (M3) * Cos (ceta)
to correct or make YAW motion, you need to change ceta of Motor 3 using the Servo. But wait This will affect equation #2.
changing ceta will not only correct the YAW but will corrupt the pitch balance in equation #2, and then thrust of M1, M2 & M3 needs to be corrected
again to correct the picth. but wait this will corrupt equation #3 because the YAW will be affected again and again in infinite loop :)
So if you correct YAW using Motor thrust angle, and correct Picth using M3 Thrust then equation #2 & #3 will affect each other, but the Tricopter will be balanced as a whole, because correction is so fast and accurate especially when using a digital servo.
THERE IS A BIG difference between Quadcopter & TriCopter in flying concept.
The main advantage I can find in Tricopter because of the Servo:
1- You can get more agressive YAW motion compared to Quadcopter, as Thrust is used for YAW not moment, and thus force for YAW control can be higher.
2- You do not need to care about CCW & CW props as long as motors & their props rotates in the right direction, the servo will correct any moment even if all motors are CW or CCW. does not matter.
Best of All is Tilt motors for Racer FPV:
in Quadcopter if you fly in X mode and made front motors tilted to gain speed while keeping the frame horizontal for better aerodynamic.
In this situation the Roll correction will YAW deviation because thrust vector is not vertical to frame and when one motor corrects the Roll by increasing thrust it will cause YAW motion because of thrust horizontal component.
Things will be worst if the same motor is used to correct YAW using moment in the opposite direction, then YAW will not be stabilized at all.
in Tricopter this will not happen, actually you can build a fast Tricopter with tilted motor, and just ignore this effect, because YAW correction happens by the third motor servo, and equations 2 & 3 already affect each other, and will actively stabilize.
  • So personal observations:
    - In bright daylight TRIs give much better orientation feel (completely Agree to Jonh)
    - If servo is not undersized (thus increasing its realiability), less ESC/Motor count results in higher reliability for TRIs
    - More space on the frame, the space which isn't covered by Props
    - On SERVOs:
    - In my tests micro servo has never exceeded 2Amps @ 5Volts.
    - If you stall a servo, however, that will virtually kill 5V RAIL, resetting Flight controller etc. So limiting servo motion boundaries via configuration, but not mechanically is crucial.
    - A separate 5V RAIL is recommend for a servo.
    - Stock (i.e. HK frames) servo mechanisms are absolutely impractical - torque direction rods are tilted (thus reducing effectiveness), to many parts which break upon every stronger impact. Bolts get loose upon each flight. Simple, well built tail boom can eliminate most of problems with TRIs.
  • Just to clarify I wasn't talking about active motor tilting.
    There actually are a few quads that have active motor tilting, but I don't think the gains are worth the extra mechanical complexity and weight, although at least one example does achieve very high speed forward flight.
    I was suggesting fixed equal forward tilt on all 4 of a quads motors to allow alignment of the frame with the direction of travel and this definitely benefits more if a lightweight aerodynamic shell is included.
    According to mark, a severe tilt might be a real advantage for racing, but it is possible that a shell that was aerodynamically neutral at the at speed achieved tilt would work too.
    Since it also presumes optimal operation at a specific forward speed, this design is really only optimized for high speed or competition FPV use.
    Probably not so useful for general purpose or video or photo use although if you were doing follow me on action sports - maybe.
    Actually a bigger problem that I continually see is the use of flat wide motor arms that interfere excessively with the propeller downwash.
    This is because it is easy to make CNC G10 or carbon fiber arms even one piece with the main frame.
    It does not provide optimal prop efficiency however and is solid flat plate area, so a dead loss to propulsion.
    Round tubes cut the loss in half and aerodynamic arms can make it vanishingly small, basically the horizontal flat arms are awful.
    Just basic aerodynamics 101.
    You can also mount the motors under the arms because in-wash losses are much less than output losses.
    But then you have problems with ground clearance and landing gear.
    This stuff holds true for both quads and tris, but tilting the movable motor forward is not so easy on a tri.
    Best,
    Gary
    Tricopters tend to be a favorite if the pilot has previous experience flying helicopters since the feel is similar. Another plus for tri is that it's easier to keep visual orientation. But other then that, quad wins in most areas.
    Hi MHefny,
    If you tilt the front two motors forward you will get a good low drag profile. You will need to adjust your pid gains to ensure the roll authority doesn't drop and the copter becomes unstable. You could probably go to 60 degrees using this simple approach and get good results.
    Tilted motors on quads:
    There are a bunch of problems with that approach and all depend on the particular implementation. Just rotating a standard quad's motors forward quickly results in halving the disk area and killing your pitch control. The result is much lower efficiency and poor control.
    A better design is to improve the aerodynamics in that fast forward flight condition. This was my first attempt and I achieved 140km/h sustained flight at 60 degrees lean angle. This could have been faster if I didn't have to carry a relatively large payload.
    http://diydrones.com/profiles/blogs/printed-high-speed-avc-copter-a...
    I have a plan for my next version :)
  • Gary,
    I haven't used digital servos yet.  In my experience the servo's power draw is minimal.  The reason I mentioned micro quads is that you generally have smaller batteries on them, and there, and additional 100mAh might be an issue.  At anything bigger you won't even notice it.
    The efficiency gain I believe is also a result of having fewer motors but coming up with data to back this up would be difficult.
    I do agree with Leonard on most points, except on the motor tilting.  But I also find most of the tilting motor designs a little silly, here's why.
    An H quad's centerpiece tends to have a considerable surface area.  With statically mounted motors that surface is perpendicular to the air flow so it's a source of inefficiency (admittedly a small one, because most air flow is through the rotor discs).  When you're in a translational motion most airflow over the copter is still perpendicular to the rotor discs even though it might seem like you're flying a fixed wing.  In a fixed wing the airflow over the body is the opposite direction of your movement and there, keeping the body flat obviously makes sense.  In a copter what you should be doing when moving forward is to actually tilt the airframe slightly to the back while tilting your motors forward, if you care about the aerodynamic properties which I'm not sure is really worth the effort anyway.
  • Gray
    I liked the idea of tilting the board, either physically or in firmware.
    Leonard,
    Thanks alot man.... alot of info here I didnt know.
    What I try to suggest here is that tilted Tricopter with adapted firmware to Keep the frame horizontal whatever condition will allow it to go fast because you can then build an aerodynamic body that will face wind from front only. as the tilted Tri is capable of speed up by change front motor tilt rather than tilt forward the body.
    Could u guys give me feedback on this point.
  • Gray
    Thanks for the feedback .... really useful to me.
    I guess building H frame quad with tilted motor will be more like this . There will be no issue between Roll and Yaw.
    The point that I wanted to highlight in TriCopter is that Tricopter equations because they affect each other, so when there is Row/Yaw interrelation the equations actively solve it, but this is not the case in Quadcopter that need separation between Yaw & Roll.
    I have to put my hand up as a tricopter fan! It might not be for very valid technical reasons but they just feel nicer to fly.
  • Hi Leonard,
    I do think it is important to note that the only reason tricopters with the same total swept prop area as an equivalent quad are more efficient is because of the larger prop diameter in the 3 propellers of the  tricopter to acheive the same swept area as the four propellers of the quad.
    For the simple reason larger diameter props are intrinsically more efficient than smaller ones.
    @ Andrew, Even given that the servo, especially under competition conditions, and especially if always on digital is going to be drawing significant current (More than a GPS - a lot more) and this loss cannot be simply discounted, the weight is not what is important, the power draw is.
    The only real issue is does the irretrievable loss in the servo operation get made up for by the increase in prop diameter for equivalent swept area.
    I would suspect under some flight conditions it does and under others it doesn't.
    And the servo and it's attendant mechanical implementation method do represent a structural and failure prone weak link on a tricopter, especially in "mishaps".
    Basically I am in agreement with Leonard, although I think that wwith a streamlined appropriate shell a case can be made for forward prop tilt for high performance copters, Quad or Tri.
    And as he said, just line up the flight controller (IMU) with the horizontal prop Axis and even existing ones are pretty much self compensating.
    Of course, the IMU could be offset in firmware as well.
    Best,
    Gary
  • I have been flying a tricopter with Arducopter for about 4 years doing mapping and have had no tuning problems. Tricopters seem to be easier to keep orientation for some reason.  I agree on the efficiency, with 2D flat map gimbal and canon s110 I get ~30 min on 4s 8000mah.  The weak link for me is the servo.  I use a large and fast metal gear digital on the rear when running a 14 inch prop using MK motors.  I have had to replace two due to slop in the gears.  Wish Arducopter would add a Y4 configuaration.  Good discussion, guys.  3702114750?profile=original
