ok, so home from dinner and ready to unwrap to see how it goes.
the good news is the cling wrap released from the wooden mold, and is actually very smooth on the inside, there are a few crinkles in the outer carbon, but these will not be noticeable once the excess is trimmed to size and glued to the 2nd half. the fuse is very rigid already from front to rear and twists side to side, but adding the other half should make it stiff in both directionsrichie
hi, the cover material is 100um builders film from the local hardware store, i think it is a polypropylene. the real vacuum bags use a nylon film but this is rather expensive and hard to get here in oz in small quantities. the only hassle using the buildings film is that it has folds in the sheets and these can leave an imprinting in the finish of the epoxy.
Close up of the finish, a little rough but super strong and after gluing the 2 halfs together cant be twisted by hand.
Oops, I didn't see this post, so forget about the question on the first post. Looks good. The carbon is unidirectional in strength, so if you really want it to be oober stiff in both directions a cross directional layer would do that for you, but I believe the other half would take care of the twisting.
Can you explain the film you used for the vacuum cover? I've thought of using cheap shower curtains, but now sure how well that would work.
